Collective Nouns
agedgopher
Seasoned Pro
Fixes: 12
Collective Nouns
This morning I have seen at one location 3 Openreach vans parked around a roadside box, with engineers clustered under a polythene tent. Less than half a mile away there were 2 more vans with 4 engineers all looking into a hole in the pavement.
Being an inquisitive sort I started to wonder what the collective noun for such a cluster of Openreach engineers might be.
16 REPLIES 16
journeys
Re: Collective Nouns
A "disconnect"
agedgopher
Seasoned Pro
Fixes: 12
That is a good one. I thought it might be a skive.
journeys
 'Skive' Cheesy
A void?
Mav
Fixes: 431
A cabinet of Openreach engineers?
Forum Moderator and Customer
gleneagles
Fixes: 16
We have a couple of boxes at the end of the road and hardly a week goes by without one or two openreach vans parked next to them with someone fiddling around inside the boxes.
Causes me a degree of anxiety because my broadband works fine and I want it to stay that way, just one wire gets accidently disconnected and then I will be joining the long list of customers who often wait ages to get problems fixed.
Perhaps I should weld those doors closed ?
Wink
We are born into history and history is born into us.
2u2me
A    cheesed off
agedgopher
Seasoned Pro
Fixes: 12
Rather than weld the doors shut, try welding them in the open position. That will cause some head scratching.
@Mav - Pure genius.
Minivanman
Aspiring Legend
You are on the right lines Mav..... Wink
For a cabinet of engineers would we need at least twenty one of them as they do in government but then again, a council of engineers does not quite work either!
Don't limit the friends you haven't met with arguments you'll never have.
MauriceC
Fixes: 17
A confusion of Openreach engineers?  ........ Probably  to close to the truth?
M
rongtw
Fixes: 12
Are you sure the were not lemmings ,,,,,,,,,,,  looking for the lost engineer down the hole Cheesy
twocvbloke
An interference of engineers...
agedgopher
Seasoned Pro
Fixes: 12
Fantastic, that's the best yet
