Coffin Contents
Fixes: 15
Coffin Contents
Variation on a theme.... desert island discs requires the castaway to pick 8 records and one personal object to have on their desert island....
What "personal object" would you want to be placed in your coffin, to help you in the next world?
Me? .... I would have a box full of  "peace and quiet",  because anything else would make it rattle !!!  Cheesy
Re: Coffin Contents
I just want to go in with all my teeth intact (although they are plenty of fillings and a couple of crowns).
Fixes: 154
Re: Coffin Contents
Tough one.... gotta be my ipod whereas my sister wants a bell.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 58
Re: Coffin Contents
Can't believe you did it Grin
Oh well here goes:
A laptop with inter-dimensional access for reading the forums from 'the other side' Wink
A jar of Horlicks.
A self refilling bag of dry roasted peanuts.
A screwdriver.
Customer and Forum Moderator.
Fixes: 154
Re: Coffin Contents
New Glasses Strat?
Quote from: shutter
Object not objects, now stop cheating  Wink Grin
Fixes: 58
Re: Coffin Contents
Taking into consideration all objections to my post and after long and arduous deliberations I have finally come to this conclusion. Roll eyes
It has to be the Horlicks Cool
Fixes: 15
Re: Coffin Contents
Strat just wanted a bit of "home comforts"... he and I had prior knowledge of this post, and he suggested having the central heating on, and a couple of cans in the fridge...... (wow !  What size coffin Huh?)  Cheesy Cheesy Cheesy
Fixes: 154
Re: Coffin Contents
Sounds more like a mausoleum  Grin
If so I'll bring along my tell and PS3...
Fixes: 15
Re: Coffin Contents
Point of order here chaps... (and chap esses!!)
You will be DED ... so tv and ps3 not much use in the "other world"... How do you know you can get new games, and will the existing tv work on the "other world" frequencies, although  I suppose it will probably be  DIG it ALL !  Grin Grin Grin
Fixes: 58
Re: Coffin Contents
But the 'other world' might just be another dimension where everything goes eventually and there is a 1 way valve for information so you will be able to read but not post and you'll be able to download new games for your console and omnibus editions of Corry and Eastenders stream across with a total lack of inhibition and dental services are all free at the point of the drill.......ramble......ramble Crazy
Good night all Zzzzzzzzzz
Fixes: 15
Re: Coffin Contents
There your are, Strat............ too much horlicks and the mind frazzles !!  Cheesy Cheesy
Re: Coffin Contents
tricky...
what goes with ashes?
madjbright
Re: Coffin Contents
Quote from: artificer
Sack cloth!!!
Fixes: 58
Re: Coffin Contents
Spot on Madjbright Grin
Re: Coffin Contents
oh, right. cheers.  that's me sorted for the hereafter.
my ashes can go into the sack cloth. Grin
