Clothes Drying Rack (Heated)
30FTTC06
Fixes: 4
Anybody using or tried one of these ? I can't see that It will be any good in terms of spreading the heat equally.
My guess @ 300 watt is around 4/5 hours drying time @ 11.4p per KW hour /1000x300=3.42 x 5=17.1p.
A 2.5kw dryer would work out around 28.5 for an hour. BUT! with a  drying rack my clothes won't shrink.
Any thoughts welcomed.
11 REPLIES 11
petlew
Re: Clothes Drying Rack (Heated)
I will be interested in any replies, as I have also been considering buying one.
journeys
SWMBO considered it, but she argued with herself  'somehow you need to get the dampness out of the room'.
She finally settled for a room dehumidifier and a cheapo drying rack from Argos.
With the drying rack fully loaded the dehumidifier extracts 20 litres of water over an 8 hour period,
Uses 240w per hour (ie 22p, more expensive than the drying rack, but doesn't shrink clothes.
RobPN
Fixes: 5
@journeys wrote:
... With the drying rack fully loaded the dehumidifier extracts 20 litres of water over an 8 hour period,
That seems to be a lot of residual water from the clothing, especially if it's been spun!
Or perhaps you have a large amount of washing  Wink
twocvbloke
I've a rather useful device that dries clothes slowly and also vents accumulated humidity to the outdoor world, it's a tumble dryer with a low heat setting... Crazy
journeys
probably also collecting moisture from the utility room.
30FTTC06
Fixes: 4
We run a dehumidifier and don't get anywhere near 20, maybe 5 to 10 but we double spin everything at 1400 first.
I hadn't thought about containing the washing in one room though as we push everything around the radiators to catch morning/evening cycle. Our dehumidifier is 440 watt full blast, so maybe we will give that a try with a simple rack first.
gleneagles
Fixes: 16
Like others I have thought about one but talked myself out of it as there are just the two of us so we are not washing stuff every day.
From what I can work out a tumble dryer costs about 40p for 1 hour of drying, this rack costs 6p per hour but that raises tho questions for me,
1. Will this drying rack dry all your clothes including bath towels etc in 1 hour ? if not, how long will it take.
2. Assuming you have an efficient tumble dryer how long will it be before you recoup the cost of the dryer rack ?
There is also the question of space, perhaps it folds down, if not some people might have a problem where to keep it.
We are born into history and history is born into us.
Minivanman
Aspiring Legend
We've got one of these Wink
Don't limit the friends you haven't met with arguments you'll never have.
In the UK, when it's too wet or cold to hang clothes out to dry, we use one or more of these.
Clothes hung up around 8am, are dry by 3pm most days.
We have it set up in a small Toilet room, and just leave the window ajar.
We use 4 pegs on Boxers & Polo Shirts, creating a gap in the middle of each item, to ensure good air circulation.
Sometimes, we do have to Top & Tail Large Towels, but generally not.
TBH we tend to Tumble Dry large Towels, 'cos we like 'em "Soft & Fluffy"
In Hong Kong though, it's a different matter, almost exclusively we Tumble Dry everything we can.
This is a fairly normal sight as you wander round HK at the moment, the High Rise "Flats" are really quite small, so any washing is hung out in/off the balcony, by the residents.
High Temperatures, but also High humidity.
Many resident have those pull out string dryers across the bath.
Fortunately, our Friends & Family tend to live in larger accommodation, across the River
gleneagles
Fixes: 16
Yes but what do you do if it's damp or raining, ?
What you need is 6 lath victorian vintage ceiling pulley maid clothes airer.
Bet you have seen a few of those when you were a young lad !
Wink
rogadodge
If you go to Argos and order 4 of these  http://www.argos.co.uk/product/6144616?storeId=10151&referredURL=http%3A%2F%2Fwww.argos.co.uk%2Fprod... overdoor airers, 2 for £15. It stacks with 25% off orders over £25 (this discount is on full price not discounted price). Using code HOME25.
When you get the item you get 4 of these  http://www.argos.co.uk/product/6049780?storeId=10151&referredURL=http%3A%2F%2Fwww.argos.co.uk%2Fprod...
They are £24.99 each.
You get 4 of these for £17.01.  They are stock numbered incorrectly in Argos. You do get the more expensive , freestanding one.  Or you could select any 4 of the 2 for £15 items, and get them all for between £14 and £20.
is taking advantage of this glitch immoral?
