Clocks have gone back
- General Chat
- Re: Clocks have gone back
28-10-2007 8:44 AM
28-10-2007 8:56 AM
28-10-2007 9:18 AM
My PC, mobile this forum and my sky plus box all say 9.20
Usually XP sorts this out ..
28-10-2007 9:25 AM
28-10-2007 9:33 AM
28-10-2007 9:40 AM
Quote from: Spider ..and it looks like the forum as forgotten that the clocks changed as well. Before any one comments I have my profile set to the forums default time!
I have the offset set to 0 and it's saying the forum time is an hour ahead. Looks like there's a setting that Plusnet or the moderators need to change.
28-10-2007 12:26 PM
28-10-2007 2:20 PM
and on PUG it says
This post was made at about 14:20 GMT
It is also apparent that either this server or the PUG server is not using a time server as there is about a minutes difference.
Moderators: As I've proved that this is a fault with the configuration of these forums, may I suggest this topic is moved to the Community Site Bugs forum.
28-10-2007 3:11 PM
my off peak usage has been put in peak usage
28-10-2007 3:44 PM
Edit: Link corrected
28-10-2007 3:59 PM
I did forget the central heating but my alarm clock's ok thanks to Rugby.
Customer and Forum Moderator. Windows 10 Firefox 84.0.2 (64-bit)
28-10-2007 4:07 PM
28-10-2007 4:11 PM
It matters not.....it's the content that counts.
28-10-2007 5:11 PM
Quote from: jelv Thanks to Matt Taylor (orbrey) the forums are now set to the right time. If anyone is seeing the wrong time go to here and set the time offset to zero.
tells me i am not authorised to edit profiles - is it pointing to yours?
28-10-2007 5:21 PM
