Clocks have gone back
pcoventry76
Don't forget - i did  Grin lol
47 REPLIES 47
Re: Clocks have gone back
..and it looks like the forum as forgotten that the clocks changed as well. Before any one comments I have my profile set to the forums default time!
pcoventry76
hmm so it is not about 9:20 now?
My PC, mobile this forum and my sky plus box all say 9.20
Usually XP sorts this out ..
Yes it is but my forums times are showing as one out later! Looks like I am going to have to manually override the default setting.
pcoventry76
im not bothered really i just read the threads new today
Fixes: 10
Quote from: Spider
Huh There isn't a time offset setting for forum default (there is one for the time format, i.e. where you can set dd/mm/yy or mm/dd/yy).
I have the offset set to 0 and it's saying the forum time is an hour ahead. Looks like there's a setting that Plusnet or the moderators need to change.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
pcoventry76
i see the usage is messed up too its showing 148mb done in peak but it was done before 8am but also despite being in my paid for bit the amount of paid usage has stayed the same
Fixes: 10
Well I've noticed one or two PN people about as well as moderators and still the time on these forums is wrong. I've just compared my settings on these forums with my settings on the PUG forums and they are the same. However on these forums in my profile it says
Local Time:  Sun 28-10-2007, 15:16:08
and on PUG it says
Local Time:  Sun 28-10-2007, 14:17:03
This post was made at about 14:20 GMT
It is also apparent that either this server or the PUG server is not using a time server as there is about a minutes difference.
Moderators: As I've proved that this is a fault with the configuration of these forums, may I suggest this topic is moved to the Community Site Bugs forum.
pcoventry76
i am thankful it was only 148mb i did before 8am and not GB's
my off peak usage has been put in peak usage
Fixes: 10
Thanks to Matt Taylor (orbrey) the forums are now set to the right time. If anyone is seeing the wrong time go to here and set the time offset to zero.
Edit: Link corrected
Fixes: 365
Cheers guys
I did forget the central heating but my alarm clock's ok thanks to Rugby.
Customer and Forum Moderator. Windows 10 Firefox 72.0.2 (64-bit)
Life is tough enough without adding Linux into the mix.
Cheers for the heads up Jelv
Fixes: 365
The same thing happened last year if I recall correctly.
It matters not.....it's the content that counts.  Smiley
pcoventry76
Quote from: jelv
tells me i am not authorised to edit profiles - is it pointing to yours?
Fixes: 365
Yes it is......ooops Wink
