Chilly, Willy Weather
Re: Chilly, Willy Weather
@Anonymous wrote:
@Anonymous wrote:
Extra Chilly Wednesday Night & Thursday morning, here in Derbyshire countryside
-3ºC  forecast
As forecast, overnight here it was a very cold -3.4ºC
The local TV weather person last night warned that any lying snow would probably thaw yesterday, and freeze overnight.
This exactly what happened.
I ventured forth this morning, there  is a particularly long, steep hill near me, and there were casualties, of sorts.
Stuck on the hill, wheels spinning, were a Honda SUV and a Range Rover.
Jeep..... no problem, didn't even have to utilise the 4WD Lo setting.
I just sailed past and gave them a cheery wave.
Bye !!
I was out shopping in the Jazz yesterday, it was quite a pleasant day, however the Traction Control kicked in a few times.
Back to Jeep...
Fixes: 7
Where I used to live (not far from where I am now).
Going to the station was downhill and it is steep. Pavements were iced over and I thought "Errm I don't think I should walk down here" (think of a more sweary version of thst remark and you'll know what I mean :smiley:).
I ended up walking down the tracks of cars where the road was clear and avoiding cars when they came down.
The Council decided that our local small town (Glossop) needed a make-over.
One of the things they did, was purchase a load of very flat smooth pretty paving stones.... from Italy I think.
They didn't take into consideration that the High Street has quite a steep incline....
You can guess the rest !!
After several pedestrian falls on the smooth paving slabs, when wet, or especially when icy or snowed over, there was a lot of complaints.
And quite a few injuries, one person broke a leg.... who just happened to be a Councillors wife.
http://www.manchestereveningnews.co.uk/news/local-news/a-major-slip-up-883293
There is also a section with steps up to a Supermarket, yes, you've guessed it...
The Council stated they would do nothing, as the slabs were very expensive, and looked nice in the Summer !!
Eventually they came up with a solution........
Every day Council workmen would be out & about covering the slippy slabs with Grit & Sand !!
At least twice a day.
So once again, as winter approaches we can look forwards to more slipping, sliding & injuries !!
And walking in the road.
We stay away, just too risky.
From a legal forum..
26 Dec 2015 - On Christmas Eve I fell on Victoria Street, Glossop due to slippery surface.
This was obviously caused by rain.
I have looked further into this.
There have been quite a few issues with the type of tiling used in town centre.
It looks like the council is more concerned about cosmetics than safety!
Fixes: 7
Yep I live in the middle of two train lines. There are three, in South East London where I live.
I think you can figure out who my train company is now :tongue:
I usually use the middle (Bexleyheath) line as the area is nicer and if I wanted to walk it is flat but boring. Sadly it will look like I will have some hospital visits, which means using the top (Greenwich) line. For me that means walking downhill a nasty hill to my station. I have already fallen over once going downhill and that was in good weather.
Luckily a bus goes there and I think I'll be getting it to the station. It'll be cold, I can't be bothered and walking will be dangerous I suspect.
It's going to be a very chilly weekend this week from Friday 8th December ...
Definitely Chilly Willy Weather !!
With the warning of white stuff falling on London, the MET office has advised people to carry extra tissues... :2funny:
@Anonymous wrote:
In the end, I just placed the Jazz 12v battery on charge overnight, in situ.
Started no problems this warmer morning, Heated Seats & Air Con switched off.
It was noticeably quicker to unlock the doors too.
The Hybrid Jazz 12v battery is 43 months old, and has powered the Jazz for just 9,000 miles.
AFAIK it is not one of the newer Stop-Start batteries, and so is not designed to cope  with the Automatic Engine Stop - Starting which places heavy demands on the 12v battery !
Perhaps as many as ten times per journey, and with each journey quite local, doesn't get chance to fully charge up.
Will get it tested this morning, but I think for peace of mind I will just change the 12v battery every 3 years, just before the cold weather, as they seem to have a reputation for failing when it's really cold.
Works out at only 8p / day.
I also made a note of the Radio Code too.
Update 10:00
Battery tested....... REPLACE !!
Booked into Honda for replacement, as it is a 12v battery in a Hybrid car, it has to be replaced by Honda.
Only £20 more than at local Kwikfit, and they do a full safety check.
Went to Halfords today to collect some -10ºC screenwash concentrate, cars now topped up in preparation for this coming weekend "blizzards !"
Whilst I was there I had Halfords do a battery test on the Jeep 12v battery, which is massive, both in size & capacity.
Read at 560 / 650, ie good.
The tech pointed out to me that the Yuasa battery has a built in battery charge monitor...
Mine showed Recharge, understandable
RobPN
Aspiring Hero
Fixes: 5
@Anonymous wrote:
Went to Halfords today ...
@Anonymous What units are you referring to?
My Yuasa YBX3096 75ah 650A 12v Battery was new in May 2017
(it's a very large battery)
The quoted max discharge is 650A, so presumably 560A is the measured discharge rate, at the time
Cold Cranking Performance (Amps) EN1: 650
RobPN
Aspiring Hero
Fixes: 5
Not particularly large IMO  :smiley:
Sorry if it disappoints, but Your Yuasa for your massive-engined Jeep is only 36mm longer and 12Ah / 40A CCA larger capacity than the Varta Silver Dynamic which I purchased for our old 1.4L petrol engine VW Golf in October 2016. :wink:
Edit:  OT, but I forgot to mention the Varta has a 5 year warranty against your 3 years.
My previous Yuasa 12v battery lasted 6 years !!
Just checked back in Service Histories, with two Jeep GC's, the Yuasa's always lasted around 6 years.
When this one dies, I'll just buy another one....
Don't forget to wedge open your wheelie bin lids, it's going to be freezing for the next few nights.....
Local TV & Radio are mentioning there are several Amber Snow warnings for the next couple of days here in the High Peak, with Sunday expecting up to 10cms of Snow !!
 UPDATE: Snow now updated to 20cms plus, that's 5 inches !!
They've already earlier closed the two major routes between Glossop in Derbyshire & Sheffield, impassable due to Snow, earlier
The Snake Pass & Woodhead Pass.
Gritters have temporarily cleared a way through, with caution.
Pix:
http://www.dailymail.co.uk/news/article-5158749/Britain-braced-10-DAYS-sub-zero-temperatures.html
Saturday 9th December 12 noon
Weather Forecast for Buxton & The Peak District:  ...
-Weather Update:  We have scattered snow showers falling on Saturday morning ( and reports of heavy snow falling nearby!)  - we have about 8cm (3") of snow on the ground, Saturday morning.
WARNING! - there is likely to be a significant amount of snow falling on Sunday - could be 20 cm (8") + on the ground.
Current situation: Traffic is moving well,  on main roads - side roads in the Buxton area have deep lying snow, and are very difficult, as the compacted snow has frozen.
Even high level routes, in the Buxton area, including the A537 Cat & Fiddle to Macclesfield, A54 Leek, A53 Congleton, and the A57 Snake Pass, appear to be passable with care.
Latest Road Reports: "Tha A57 Snake Pass is now open" "Main Roads are fine in Buxton.
Problem this morning is ice on side roads in particular Green Lane, which is treacherous with freezing ice.
"Just driven in to Buxton from Cheadle,Staffordshire using the A53 Leek Road. Conditions are absolutely fine, the road is clear and well gritted."
Side roads very icy from yesterday's melt re-frozen."
