Chilly Willy ..... Get out your Winter Woolies.
Infinity
Seasoned Pro
http://www.telegraph.co.uk/topics/weather/9631875/Gritters-at-the-ready-for-Arctic-blast-of-winter-a...
Forecasters warned of possible snow, sleet and hail throughout the North and freezing temperatures as thousands of families start the half-term break.
Temperatures could fall by up to 18F (10C) during the first onslaught of the wintry weather.
Re: Chilly Willy ..... Get out your Winter Woolies.
And there was me hoping that global warming had finally kicked in.
Going by previous years I guess we are in for a cold dry (hosepipe ban) winter.
RPMozley
Fixes: 5
Quote from: billnotben
Roll eyes
The old common misconception of global warming again. What's happening is more energy is being put into the global weather system, causing some zones to become more extreme in terms of weather events. Think of it like a rubber band, the more you pull it the more it moves.
That's RPM to you!!
Oh gosh!! its near the end of October getting close to November and its getting colder (much as it has done for the last couple of million years in the late autumn in the northern hemisphere)
What ever next...!
kmilburn
Apart from that,  if some predictions of the effects of global warming come true,  we can expect winters significantly colder than we're used to.
This is one reason for the switch in terminology to  'global climate change',  the average may be warmer, however, YMMV.
Quote from: RPMozley
What the one that says the world is warming up.
RPMozley
Fixes: 5
No, not that one. I meant what the effect will be on the climate. Like ones where it will always be warmer than usual.
Sorry if I'm not explaining this very well, kind of difficult concentrating with an allergy going off in my nose.
That's RPM to you!!
Back to the OP Title, is Damart Thermalwear still going?
Call me 'w23'
Certainly turned very cold here in Essex this afternoon, and after a mild morning.
Must be down to global warmings effect on both the gulf stream and the jet stream. Tongue
Maybe the problem is indirectly linked to global warming:
We're all being encouraged to use higher efficiency appliance, low energy lightbulbs etc., we're also being told to improve insulation and draughtproofing (some are being offered grants for this), we're encouraged to drive cars with lower CO2 emissions (more efficient, less waste heat) - the net effect is surely much less heat going into the surroundings so it's hardly any wonder it's getting colder!  Tongue
Call me 'w23'
Infinity
Seasoned Pro
Cause it's getting colder
Growing colder, not warm but wilder
Getting colder everyday, colder everyday...
or so my Ma & Pa tell me.
Tomorrow Morning ?Huh
Steve
Seasoned Pro
Forecast as -1 here for me all next week In the evening.
If life gives you lemons, make lemonade.
Infinity
Seasoned Pro
Horizon, this week. (on BBC iPlayer too)
Global Warming is just that... Global.
Within which, regional variations account for colder winters.
Series exploring topical scientific issues.
Horizon follows the climate researchers investigating the strange patterns of severe weather seen around the world in recent years.
Infinity
Seasoned Pro
Surprise, surprise...
A Daily Express weather story...
-15℃ predicted for the end of November...... in Scotland
http://www.express.co.uk/posts/view/357651
