Cheap LCD TV.
- General Chat
- Re: Cheap LCD TV.
Cheap LCD TV.
31-01-2010 8:05 PM
I don't need anything amazing, cheaper the better. It is for my little brother to play some games on, so he won't notice the difference between contrast ratios and resolution.
This is the cheapest TV I could find http://direct.tesco.com/product/images/?R=204-4482 I know its not a good brand, but again its got a kid who ain't gonna be able to tell the difference.
Can I have some recommendation please. I want it within £120. Thanks.
Re: Cheap LCD TV.
31-01-2010 8:34 PM
http://cgi.ebay.co.uk/Bush-19-LCD-TV-With-FREEVIEW_W0QQitemZ190368989196QQcmdZViewItemQQptZUK_AudioT...
or this one...... 55 Mins to go { EDIT _ Bidding has finished...... sold at £87.00 + £15 dellivery }
http://cgi.ebay.co.uk/Samsung-19-LCD-white-HD-ready_W0QQitemZ140378000504QQcmdZViewItemQQptZUK_Audio...
{EDIT _ Bidding has finished £84.00 collection from March, Cambs }
There`s a couple of others further down with more time .....
Happy Bidding !
Re: Cheap LCD TV.
31-01-2010 8:57 PM
Re: Cheap LCD TV.
01-02-2010 6:46 AM
I think 16" will be a bit too small, but thanks for the suggestion.
Re: Cheap LCD TV.
01-02-2010 8:22 AM
Re: Cheap LCD TV.
01-02-2010 12:33 PM
I am looking for a LCD tv, around 19 to 22 inches.
I don't need a Dvd Player on it but I do want it to have the best contrast ratio and resolution, but I do want it to be cheap
Ok what I want:
HD LCD TV
Contrast ratio of: 2000 x ? But I may go for 1680 x 1050
Number of Scart Sockets I would like: 2 but I will settle for 1
Screen Size (inch) 19 or 22
HD Ready - Yes
Number of HDMI Sockets: 1
Stand Pedal.
Wall Mountable.
Stereo Sound with built in speakers.
Maximum Price Including P&P £200.00p
This is the cheapest TV I could find from Asda
I am not bothered with the brand name.
Re: Cheap LCD TV.
01-02-2010 3:58 PM
Quote from: pierre_pierre if its for games do you want a TV or a monitor?
I want a TV so he can play Xbox on it, but I can also hook up my PC.
Re: Cheap LCD TV.
01-02-2010 5:22 PM
Re: Cheap LCD TV.
01-02-2010 6:09 PM
Offer not available in-store Standard Delivery Free
Add Hitachi L19H01UBR black 19" refurbished digital LCD TV to your basketBack
THIS IS A REFURBISHED TV AND COMES WITH A FULL 12 MONTHS WARRANTY. It has been professionally checked, tested, refurbished to a like new standard and offered to you at a fantastic saving.
Digital tuner - to watch freeview channels
HD Ready 720p - Great quality on HD sources
2x HDMI inputs - HD quality connection
PC input - Can also be used as a monitor
http://www.currys.co.uk/martprd/store/cur_page.jsp?BV_SessionID=@@@@1199872617.1265048070@@@@&BV_Eng...
Re: Cheap LCD TV.
01-02-2010 6:20 PM
Re: Cheap LCD TV.
01-02-2010 6:24 PM
Screen Size (inches) 19 inches Size of the screen measured diagonally across the screen
Picture Quality 1296000 pixels The higher the number of pixels the better the picture resolution will be
Flat Screen YES Flat screens reflect less and do not curve at the edges providing you with less distortion
Widescreen Option YES A format also known as 16:9 offering you the advantage of being able to watch movies in their original format
Sound Quality NICAM stereo See our TV Buying Guide for more information
Viewable Screen Size 18.9 inches
Digital Tuner YES This enables you to receive over 25 Freeview channels, subject to coverage, including BBC Three, BBC Four, BBC News 24, Sky News, Sky Sports News, ITV2, CBeebies and digital radio channels
Brightness 300 cd/m2 The greater the brightness the better quality of the picture usually is. However the actual picture quality is determined by how well the brightness and contrast of the TV work together
Contrast 1000 The higher the contrast ratio the better the picture quality
On Screen Display NO For the simple on screen access to menu options
No of Scarts 1 To enable you to connect to other equipment such as a DVD player, video or games console
Line input YES
Stand Included YES
Parental Lock NO Unauthorised people such as children can be prevented from tampering with the equipment
Auto Install YES Automatically tunes your TV and sets up the channels at the touch of a button
Sleep Timer NO Can be set to turn off automatically
Headphone Socket NO For you to listen with personal headphones
Front AV sockets NO For easy connection of equipment such as camcorders or games consoles
Colour Black
Fastext YES Allows for faster and easier access to Ceefax and Teletext information services
Remote Control YES Enables you to operate your equipment from a remote handset
Re: Cheap LCD TV.
01-02-2010 7:50 PM
Currys Price £189.99
Re: Cheap LCD TV.
01-02-2010 8:02 PM
Re: Cheap LCD TV.
01-02-2010 10:12 PM
Re: Cheap LCD TV.
03-02-2010 2:36 PM
