Cheap LCD TV.
Addnan
Cheap LCD TV.
I am looking for a LCD tv, around 19 inches.
I don't need anything amazing, cheaper the better. It is for my little brother to play some games on, so he won't notice the difference between contrast ratios and resolution.
This is the cheapest TV I could find http://direct.tesco.com/product/images/?R=204-4482 I know its not a good brand, but again its got a kid who ain't gonna be able to tell the difference.
Can I have some recommendation please. I want it within £120. Thanks.
Fixes: 20
Re: Cheap LCD TV.
QUICK.................... get on ebay..... ony £54  and 15 mins to go....
http://cgi.ebay.co.uk/Bush-19-LCD-TV-With-FREEVIEW_W0QQitemZ190368989196QQcmdZViewItemQQptZUK_AudioT...
or this one...... 55 Mins to go { EDIT  _  Bidding has finished...... sold at £87.00 + £15 dellivery }
http://cgi.ebay.co.uk/Samsung-19-LCD-white-HD-ready_W0QQitemZ140378000504QQcmdZViewItemQQptZUK_Audio...
{EDIT _ Bidding has finished £84.00  collection from March, Cambs }
There`s a couple of others  further down with more time .....
Happy Bidding !  Wink
Fixes: 12
Re: Cheap LCD TV.
If you could survive with a 16" Alba  from Maplins only £89.99!.  Stock expected wirhin 5 days.
Addnan
Re: Cheap LCD TV.
Can I trust ebay when purchasing a TV? If its ok then wow, Samsungs for that cheap. I would get it.
I think 16" will be a bit too small, but thanks for the suggestion.
pierre_pierre
Re: Cheap LCD TV.
if its for games do you want a TV or a monitor?
Midnight_Caller
Re: Cheap LCD TV.
@Addnan, Sorry to nik your thread.  Embarrassed
I am looking for a LCD tv, around 19 to 22 inches.
I don't need a Dvd Player on it but I do want it to have the best contrast ratio and resolution, but I do want it to be cheap
Ok what I want:
HD LCD TV
Contrast ratio of: 2000 x ? But I may go for 1680 x 1050
Number of Scart Sockets I would like: 2 but I will settle for 1
Screen Size (inch) 19 or 22
HD Ready - Yes
Number of HDMI Sockets: 1
Stand Pedal.
Wall Mountable.
Stereo Sound with built in speakers.
Maximum Price Including P&P £200.00p
This is the cheapest TV I could find from Asda
I am not bothered with the brand name.
Addnan
Re: Cheap LCD TV.
Quote from: pierre_pierre
I want a TV so he can play Xbox on it, but I can also hook up my PC.
pierre_pierre
Re: Cheap LCD TV.
try this from Aldi on Thursday http://www.aldi.co.uk/uk/html/offers/2827_12859.htm 20 inch  £90
Steve
Seasoned Pro
Re: Cheap LCD TV.
Web Exclusive £109.99
Offer not available in-store Standard Delivery Free
Add Hitachi L19H01UBR black 19" refurbished digital LCD TV to your basketBack
THIS IS A REFURBISHED TV AND COMES WITH A FULL 12 MONTHS WARRANTY. It has been professionally checked, tested, refurbished to a like new standard and offered to you at a fantastic saving.
Digital tuner - to watch freeview channels
HD Ready 720p - Great quality on HD sources
2x HDMI inputs - HD quality connection
PC input - Can also be used as a monitor
http://www.currys.co.uk/martprd/store/cur_page.jsp?BV_SessionID=@@@@1199872617.1265048070@@@@&BV_Eng...
If life gives you lemons, make lemonade.
Addnan
Re: Cheap LCD TV.
Thanks for the suggestions so far. I like the Hitatchi, are there any catches with the warranty since it is refurbished? Control and everything come with it?
Steve
Seasoned Pro
Re: Cheap LCD TV.
Dont think so,ive bought a few refurb items from them and the stuffs been quite good,yes dont see why you shouldnt get a remote Smiley
Screen Size (inches) 19 inches Size of the screen measured diagonally across the screen
Picture Quality 1296000 pixels The higher the number of pixels the better the picture resolution will be
Flat Screen YES Flat screens reflect less and do not curve at the edges providing you with less distortion
Widescreen Option YES A format also known as 16:9 offering you the advantage of being able to watch movies in their original format
Sound Quality NICAM stereo See our TV Buying Guide for more information
Viewable Screen Size 18.9 inches
Digital Tuner YES This enables you to receive over 25 Freeview channels, subject to coverage, including BBC Three, BBC Four, BBC News 24, Sky News, Sky Sports News, ITV2, CBeebies and digital radio channels
Brightness 300 cd/m2 The greater the brightness the better quality of the picture usually is. However the actual picture quality is determined by how well the brightness and contrast of the TV work together
Contrast 1000 The higher the contrast ratio the better the picture quality
On Screen Display NO For the simple on screen access to menu options
No of Scarts 1 To enable you to connect to other equipment such as a DVD player, video or games console
Line input YES
Stand Included YES
Parental Lock NO Unauthorised people such as children can be prevented from tampering with the equipment
Auto Install YES Automatically tunes your TV and sets up the channels at the touch of a button
Sleep Timer NO Can be set to turn off automatically
Headphone Socket NO For you to listen with personal headphones
Front AV sockets NO For easy connection of equipment such as camcorders or games consoles
Colour Black
Fastext YES Allows for faster and easier access to Ceefax and Teletext information services
Remote Control YES Enables you to operate your equipment from a remote handset
Midnight_Caller
Re: Cheap LCD TV.
Thanks for the suggestions I am going to get: LG M1962D 19" HD Ready LCD TV  Product code: 670100
Currys Price £189.99
Addnan
Re: Cheap LCD TV.
I have that exact same tv, but in 27". It's a great tv.
Re: Cheap LCD TV.
Richer Sounds have a 19" Sharp for £139.95.
Sharp
mrmarkus1981
Re: Cheap LCD TV.
