Channel 4 catchup (4OD) goes Mac and Linux from end june
pierre_pierre
just got an e-mail with the news
web site here http://www.channel4.com/programmes/catch-up
Dear 4oD user,
You may have seen or heard rumours in the press about changes to 4oD. As a valued 4oD user we thought we'd let you know exactly what this will mean for you and help clear up any confusion.
No doubt you're already aware that you can watch 4oD Catch-Up on our new improved channel4.com (and if you haven't tried it yet, what are you waiting for?). All the content is streamed which makes it really easy to use, you shouldn't need to download anything - simply find what you want to watch and hit "Play". Oh, and non-Windows users will be pleased to know that 4oD Catch-Up on channel4.com is now Mac and Linux compatible.
From around the end of June you'll also be able to watch all our archive programmes on channel4.com. Which means all your favourites will be in one place and available for free.
Of course you're welcome to use your 4oD application until then if you prefer, although you may find that you are no longer able to download or rent some programmes or films. However you may be interested to know that many popular 4oD programmes are available to buy and keep on itunes.
Denzil
Re: Channel 4 catchup (4OD) goes Mac and Linux from end july
I should hope so too. Too many websites are geared to work with IE on Windows only.
alanf
Quote from: pierre_pierre
The title of this thread is incorrect.
pierre_pierre
Re: Channel 4 catchup (4OD) goes Mac and Linux from end june
Ta
