Change Swipe on Nokia 1
- General Chat
- Change Swipe on Nokia 1
05-11-2018 5:58 PM
Hi, Is it possible to disable the swipe to answer a call on a nokia one phone? I'm sure I've seen it display accept/decline, but I can't find it. Thanks.
Re: Change Swipe on Nokia 1
06-11-2018 3:25 PM - edited 06-11-2018 3:27 PM
Is it an Android phone? If so, that's normally displayed as a pop-up if the phone is already in use, say, if you are texting or emailing at the same time as the incoming call. If it's on standby it just wakes the phone and displays the caller id. I don't think disabling the swipe in those circumstances is an option.
06-11-2018 5:13 PM
Hi nozzer, thanks for your reply. It is an Android phone. I understand now how the display worked. I don't think there's any way to disable the swipe either.
