Cathodic Connection in water system
- General Chat
- Cathodic Connection in water system
13-02-2018 5:12 AM
From our local Parish Council Minutes - what is this likely to mean
Cemetery Matters
Clerk to contact Bournemouth Water to trace and remove cathodic connection in new area.
Re: Cathodic Connection in water system
13-02-2018 6:37 AM
I believe Cathodic connection is a way to stop rusting on a steel pipe , or a water tank
13-02-2018 8:09 AM
13-02-2018 8:12 AM
Are you sure it's not a typo, and they want to remove catholic influence from the water supplies?
13-02-2018 10:12 AM
What?
Rogue terrorist Catholic priests blessing their water supply?
13-02-2018 10:36 AM
Given that the local water supply has a minimum pH of 7.2 you may be correct and the original supply fed a steel above ground storage tank on a farm and that certainly won't be needed as it probably raises the pH to over 11 which isn't really a good idea in general
