Canon MG 5450 Printer
This is a twin tray printer , No longer available ,with separate ink tanks and scan facility I wish to replace it with something similar I wish to have it loaded with photo paper and plain paper and be able to choose without removing paper Any ideas
10 REPLIES 10
Re: Canon MG 5450 Printer
Can I suggest the Canon TS8350 it has a single tray at the front and a top-loading feeder at the rear.
 I have always been impressed with Canon printers and there use of ink compared with Epson and HP.
Thank you I will look , the 5450 has two trays underneath I could load photo paper in one and A4 in the higher one  the paper was there and should I wish I could print the odd photo without any problems save just select the source  I thought there may be similar printers available as it seems  un available now and mine has failed
Fixes: 44
@stathe   dunno what`s wrong with yours..... but  .... this site may be able to help...
https://www.fixyourownprinter.com/
Alternatively......    https://www.ebay.co.uk/p/144784532
OR.... this one seems like it may work.... if you could fix it....
https://www.ebay.co.uk/itm/Canon-Pixma-MG5450-Printer/283920824506?hash=item421afff8ba:g:x8AAAOSwnpZ...
Seasoned Pro
I think the MG7550 is dual paper feed
I have found quite a few printers not available  Pixma  TS 6350 would  be  suitable with twin trays out of stock with Argos and John Lewis and  others but available from  Aiza a Chez.  company
Seasoned Champion
@stathe  Have you tried looking on the Canon site and getting it directly from them and not a retailer?Smiley
Nothing much available on line at the Canon site  Must be down to the Virus   Thank you      So much has to come from overseas now I fear for our economy and the future    Being over 85  should I worry Huh
Fixes: 44
@stathe   Just checked  and there is one still available on Ebay...
Seller Refurbished  £129.99 free delivery..   ( or you can " Make an Offer"  ) ....
Fully Refurbished + 30 day Warranty
Scratches On Top
**With Printhead - Inks, Drivers and Cables Not Included
Read the full description... on the sale page....
the last linky on my previous post...  shows the seller has relisted it
https://www.ebay.co.uk/itm/283920824506?nordt=true&orig_cvip=true&rt=nc&_trksid=p2546137.m43663.l101...
I have purchased a Canon TS6350 and it came from Prague in 5 days it does the job with 2 trays  though ink can be expensive , non Canon  available from Amazon for a fraction of the price it all works well Thank you all
Seasoned Pro
I always use 3rd party inks as I don't print anything that needs to be light fast or any photos.
My sister found Canon printers are out of stock in most places.
