Can you guess what this is ?
Infinity
Seasoned Pro
Can you guess what this is used for ?
All will be revealed later...........
nanotm
Re: Can you guess what this is ?
a plastic pot with some zip ties strapped to it,
and you could be intending to use it for a lot of things from drip catcher to lantern /
Nope! Not really interested either.
rongtw
Fixes: 12
You off fishing for minnows Smiley
It's obviously the proverbial pot to xxx in.
Shouldn't that be xxxx?  Cheesy
Infinity
Seasoned Pro
It's nothing to do with Liquids !
Nor that sort of Solids either !
Fixes: 12
Quote from: PlusComUK
nobody mentioned solids?
Fixes: 38
Measuring out washing power?
Infinity
Seasoned Pro
Not this particular one, however we do use another similar one for measuring out washing power, for most washes we just half fill it, having noted the capacity.
And then put that amount into the powder drawer in the machine.
So a very good suggestion, thanks
Fixes: 38
Well to all intent and purpose it looks like a bucket so as it's not used for liquids then it can only be solids. Having put on my thinking cap is it used to measure dry rice?
Fixes: 12
Quote from: Mook
could be used for a gas.
the lid may be elsewhere at the moment.
Infinity
Seasoned Pro
Quote from: Mook
Another excellent suggestion, but no.
Not used for foodstuffs.
Hint: Electronic / electrical items...
Fixes: 38
Quote from: chenks76
Quote from: Mook
Tongue
That would be a bit sneaky, rendering the process pointless.
Fixes: 12
the process of guessing?
yeah, it's the missing lid that is the pointless thing about this whole debacle  Cool
