Can you get this site to load properly in Firefox - SOLVED
Fixes: 62
http://www.googleartproject.com/
All I get is a blank screen
Quote from: Oldjim
Sorted - I had Firefox cookies set to Ask Every Time and it didn't (a popup problem) adding www.googleartproject.com manually to the allowed sites fixed it
Re: Can you get this site to load properly in Firefox
IE9 shows the following:
You’re missing out…
Sorry, the Google Art Project uses technology that your browser doesn’t understand.
Install Chrome Frame for Internet Explorer to improve your experience of using the web. It’s simple and only needs to be done once.
Call me 'w23'
Fixes: 62
I saw that one and I don't intend to install it nor to use IE
pierre_pierre
I loaded for me FF 11.0, but a bit out of line on my small screen
Fixes: 62
Just tried it on an XP computer - same result as mine (Windows 7 64bit)
IanSn
pierre_pierre
got deeper into it, Interesting
Damien Hirst - 2 works
Vincent Van Gogh  149 works
Van Gogh museum  161 artworks from 33 artists
Fixes: 21
Couldn't see any problems with it.
Fixes: 19
Yup.... No problem here..... using FF latest version
Fixes: 12
Ok here in seamonnkey 2.8
Fixes: 4
Works perfectly on Firefox 11.0 on Ubuntu 10.10
Fixes: 62
Works reasonably OK in IE except it keeps saying that Chrome has crashed but I still can't get it to work in Firefox
No problem in FF 3.6 and no I'm not going to upgrade to the latest firefox.
Sorry, I forgot I even had FF as I have to use IE for compatibility with work intranet.
Looks absolutely fine on FF11 with no add-ons or extensions.
Call me 'w23'
Steve
Seasoned Pro
Working fine here Oldjim, FF11. Windows 7 x86
If life gives you lemons, make lemonade.
