Can anyone Identify
Can anyone Identify
These fonts (or something near to them)
They are from an old map I'd like to pirate Roll eyes reproduce
Re: Can anyone Identify
http://www.google.co.uk/imgres?imgurl=http://www.writeawriting.com/wp-content/uploads/2010/09/elvish... ?
Call me 'w23'
The top one looks a bit like a upper case  Missy BT  in bold. Certainly the distinctive curved "M" is similar, Unfortunately it won't reproduce here, but you should be able to download it here http://www.fontyukle.net/en/Missy+BT.ttf
If they are OS maps maybe the Ordnance Survey will tell you.
First one looks Irish based!
If they are OS then they may be bespoke.
Geoff,
York.
