Calling all DIYers
Minivanman
Aspiring Legend
Calling all DIYers
Got a puzzle I've been scratching my old head about. - how to stop my front gates swinging out onto the road.
Just finished doing a major repair job on one of them and plan to do the other when the weather warms up a bit next week.
As I hope you can see from the photo below, top left I have fixed a heavy bar which stops the gate swinging out - but only when the other gate is closed and locked down. Centre right is another heavy bar fitted to the post but this has proved ineffective and also damages the gate if it gets clouted to hard.
So what's the solution?
* Some sort of raised edge in the centre roadside, but having tried that I found that the car front spoiler catches it.
* Some sort of cable that would catch and retain the gate as it swung out? Hmm
I feel sure I've seen some sort of heavy duty sliding bar assembly a bit like those security catches we have on the inside of our front doors, but not knowing what that are called and having tried several variations I cannot find anything online. Obviously both of the gates are held back with a heavy hook and eye arrangement fixed to another post and the gate which you can just see on the left behind the gate, but this does not stop it swinging back out onto the road if one or both are left unhooked by callers and yes, I'm looking at you Mr Parcel Delivery fella!
Suggestions welcome from some joint head scratching.
Cheers as always guys. Thumbs_Up
Don't limit the friends you haven't met with arguments you'll never have.
19 REPLIES 19
idonno
Aspiring Champion
Fixes: 6
Re: Calling all DIYers
How about something along the lines of a Monkey tail Bolt. They come in all shapes and sizes. Drill a hole in the slab and down it goes. Holds the gate where you want it without straps etc.
My preferred option though is electric gates........................... Cheesy
Ever helpful. Grin Sure, I’d love to help you out. Now which way did you come in?
Minivanman
Aspiring Legend
@idonno
I have those already fitted for when the gates are closed and locked at night. It's when they are inadvertently left open allowing them to swing free that is the problem. Needs something to stop them going out into the road and either hitting a car or somebody walking past, which would be an insurance claim nightmare I'd imagine.
Electric gates would be nice, but maybe a bit too posh for around here. Wink
gleneagles
Fixes: 16
Drill a hole in the ground in front of the open gate, put a small pipe in the hole to stop it closing up then put a short rod in the pipe which will prevent the gate from swinging open......bend the top of the rod to make it easier to remove.....job done !
Smiley
We are born into history and history is born into us.
gleneagles
Fixes: 16
Failing that a hook and chain to keep the gate open ?
Minivanman
Aspiring Legend
@gleneagles
Got that as well, which is why generally during the day the gates are left open and hooked back.
Maybe that is the only answer?
PS. Considered that pipe idea, but a permanent one would be no good for my car tyres. Interesting idea though about a movable one. Roll_eyes
shutter
Fixes: 47
Good strong post, e.g. scaffold pole sized pipe, about where the leading edge of the gates are, when open, as in your pic,.... attach a wire "strop" as a fixed item to gate, and to post... if gates are left open, and the wind blows them closed, they can only travel as far as the strop will let them...
( You could include a strong spring, so that the weight and motion of the gate does not pull the mounting off the gate at the point of closure ! )... metallics-everbilt-wire-rope-803182-64_1000.jpgsprings.jpg
Minivanman
Aspiring Legend
@shutter
Thanks, been mulling that over.
Like the idea of that spring and it would need a second post as well. Hmm.
7up
Fixes: 14
Tilt the gate posts backwards slightly. Then the gates won't want to swing out.
Minivanman
Aspiring Legend
.... not until the wind catches them. Wink
If they were open or wrought iron gates instead of being paneled I guess that would work.
gleneagles
Fixes: 16
What I have seen when on rights of way across farmers fields gates that are designed to close after someone has walked through them.
Now't fancy, just a rope attached to the gate and post with a heavy stone or bricks attached to the middle of the rope, as you open the gate the weight pulls down on the rope.
Only negative thing is that it's unsightly..........but cheap and effective.
Smiley
7up
Fixes: 14
With a house in the way (or garage) it's unlikely there would be enough wind to blow the gates "uphill" on their hinges / gate posts.
VileReynard
Fixes: 19
Stick a bit of metal in the ground, where the two gates are supposed to meet.
Any swinging won't be all the way into the road, then.
Alternatively, park a car in the middle of the drive, so that if the gates swing then the car prevents any excess swinging.
Minivanman
Aspiring Legend
Well apart from potential damage to the cars bodywork (if I understood you correctly) any 'bits of metal' would have to be sticking up out of the ground by around eight inches. Four inches from ground to the underneath of the gate then at least another four in order to cover effectively the horizontal timber along the bottom.
Even at half that height my tyres are not going to like it should I catch them as I swing into the drive. As for the unwary visitor....
VileReynard
Fixes: 19
Of course, first you resurface your drive to reduce the height of the 'bit of metal' ....
