Calling Mathematicians...How does this work
Fixes: 102
There are some clever guys on the forum many of whom will know how this works.
Just follow the simple instructions.... Huh
Customer and Forum Moderator.
Firejack
Re: Calling Mathematicians...How does this work
Ok that has freaked me out. How is that possible?  Huh Huh
The key is in adding the numbers together then subtracting from the original - this gives a certain number of "hot numbers"
eg:
20  = 20 - 2 = 18
21 = 21 - 3 = 18
22 = 22 - 4 = 18
23 = 23 - 5 = 18
24 = 24 - 6 = 18
25 = 25 - 7 = 18
26 = 26 - 8 = 18
27 = 27 - 9 = 18
28 = 28 - 10 = 18
29 = 29 - 11 = 18
30 = 30 - 3 = 27
Them, they have the same symbol on each of the 'hot numbers' (which all happen to be multiples of 9)
9, 18, 27, 36 etc. etc.
Peasy Smiley
B.
Firejack
But still this gives more then one possible outcome. So how does it know what Symbol to display?
Look at it again
When you get to the results screen, 9, 18, 27, 36, 45, 54 etc all have the SAME image
The selected image on each iteration is different, but the important thing is that the same image is on every one of those numbers
So they just display that image
B.
James
Clever.
pcoventry
It got 2 out of 3 right for me which is very good. It's almost as freaky as the spinning girl we had.
So what number did it get wrong or was it your maths  Grin. Sneaky the way they change the images associated with the numbers.
Fixes: 102
Like I said
Maybe not as many as I first thought, and I include me as I don't have the patience, but I knew Barry would be in there Smiley
Embarrassed
Ok, so I can't help it Wink  It's one of those things that I *have* to figure out Smiley
Part of my OCD obsession, along with listening to the radio in the car with the volume on an even number.
O dear, I'd better stop Smiley
B.
Fixes: 102
Quote from: Barry
Embarrassed
I bet you are one of these people that sorts your small change by size and then chucks it back in your pocket.
*Guilty by admission*
When I get some biscuits with my coffee I have to get 4...not 3 or 5.
Choose a two digit number: XY
Your number is therefore 10X+Y
Add together the two digits X+Y
Subtract from the original number gives you:
10X+Y-(X+Y)
Simplifying cancels the Y and reduces it to 9X
The table of characters always has the same character for all values of X, ie 1X=9, 2X=18, etc
So irrespective of what number you choose, the symbol will always be the same as that on every 9th digit.
[i]It's the PlusNet Way[/i]
Wow... they always did tell me that algebra would be useful in real life. Now I know how.
Well OK I know it has a lot of uses. But now I've seen one while I was thinking about it.
Quote from: Strat
Er, I'll get me coat..
I'd better check that there's no change in the pocket.....
The problem is - I always thought doing that was completely normal...
B.
Fixes: 102
I'm beginning to think it was a bad idea starting this thread......
No I tell a lie.....I'm absolutely certain it was Cheesy Cheesy
