Cables, don't you just. love em
gleneagles
Fixes: 16
How long would it take you to connect a modern tv to a soundbar assuming both items were working ok ? five minutes ?
two minutes ?
Well I claim the record for the longest time it took to set the above up.
Minimal instructions provided but no real problem, just plug the HDMI cable in to each device, set the tv for the device and away you go except it was no go, must have spent several hours, connecting, reconnecting and trying several spare HDMI cables but still no joy, tried the optical connection and that worked ok.
So checking the internet I discover there are several types of HDMI cables and there is one with ethernet connection used for the sound, purchased one from cpc which is 10 minutes away from me and everything works fine.
Why do these companies not supply the appropriate cable with the box ? cost is around £3 or if they are too tight to do that at least include in the instructions that this specific HDMI cable is required.
I bet some people has actually returned goods like this thinking they were not working.
Sure all you IT guys will be aware of the above but the average person ie: me. will not be aware of it
We are born into history and history is born into us.
29 REPLIES 29
DaveyH
Champion
Fixes: 12
Re: Cables, don't you just. love em
The HDMI with Ethernet isn't used for sound, it's used to network together devices that support it.
http://www.hdmi.org/manufacturer/hdmi_1_4/hec.aspx
Sounds more like to me like you're using the ARC (Audio Return Channel) feature introduced in HDMI v1.4 but weren't using the appropriate ARC enabled HDMI sockets
http://www.hdmi.org/manufacturer/hdmi_1_4/arc.aspx
Browni
Aspiring Hero
Fixes: 52
I used Bluetooth to connect my soundbar Cool
Ex-Plusnetter now living life in the G,fast lane!
rongtw
Fixes: 12
Well at PC world Sad  the salesmen do tell you if you need a cable ,,,, BUT
they sell you the most expensive ones , My neighbour was sold a Gold connection one £29.99 , hes unsure how to connect it he asked me around , had a look Hold on i said dont open it , went into my alladins cave of cables Smiley  found a free one i got with a GFX card ,, and he was away Thumbs_Up took his back for a refund Smiley
PowerLee
When I added a sound base to my tv, I just connected both via the HDMI ARC sockets with a suitable HDMI lead & then changed 1 setting for sound set up on the tv.
The HDMI ARC sockets provided on modernish equipment makes set up basically easy for people.
7up
Fixes: 14
You forget that back in the 80s it was too much for them to include a mains plug that could be found in a £1 shop. Actually thinking about it, it's probably the huge numbers of them made for £1 shops that brought the price of them down but either way, back then you still had to get it fitted if you couldn't DIY and the applicance didn't come with one.
These days everything comes with a mains plug and the supplies of spares that people like me have kept around the home seem redundant (I've not fitted one for over 10 years) and I'm amazed that shops still sell them quite frankly.
So when you put it into perspective, that £3 cable might not be much to you but you're still luckier than you would have been 30 years ago!
twocvbloke
Ugh, plugs, I hate the moulded plugs, especially when they put them on high current devices and they subsequently melt, or deform, so I keep phenolic plugs to hand for when I need to upgrade them to something a little bit more resistant to burning up... Crazy2
Though speaking of moulded plugs, I "fixed" nextdoor's old washer (behind which they suffered a squirty water leak and the plug & socket got soaked) by lopping off the charred plug (due to it arcing across the wet plug) and fitting one of my phenolics, and the washer came back to life, running off an 800VA UPS, in the shed, with no water supply, so ended up with a free washer, it's a POS, but it's still free... Funny
Luzern
Fixes: 9
It's a bit the same with USB cables. Like early Fords the plugs to the appliance end come in many sizes, but they're all black. Takes ages to find the one to charge the phone .
gleneagles
Fixes: 16
Thanks,
I was using the correct sockets as they were clearly marked and worked first time with the appropriate HDMI cable but thanks for the links
Smiley
Strat
Fixes: 506
I have an LCD TV and an AV receiver.
I have to use an HDMI lead and an optical cable to get TV sound into my AV unit because my TV doesn't have ARC.
Yet another reason for upgrading my TV.
Customer and Forum Moderator. Windows 10 Firefox 88.0.1 (64-bit)
Minivanman
Aspiring Legend
My love hate relationship with cables is when the damn things get tangled up. How the heck does that happen? You put them away tidy enough and when you go to use them again it's as if some gremlin tied knots in them, and heaven forbid you put several away in the same box - that's just asking for trouble!
It's a mystery I have yet to solve. Crazy2
PS. And don't get me started on having to untangle last years Christmas lights. Grrr.
Don't limit the friends you haven't met with arguments you'll never have.
Luzern
Fixes: 9
I've tried to get over the tangle problem by elastic bands to hold both ends together on those not in use at time,
gleneagles
Fixes: 16
And don't get me started on transformers. Sure they are all marked with voltage and amp output and some of the devices we use them for are usually marked with similar information but if it's in a case or not clearly visible does anyone bother checking, although rare there have been cases of fires where the wrong transformer was used.
VileReynard
Fixes: 19
Back in the olden days...
You had serial cables and parallel cables each had multiple connectors e.g 9 pin or 25 pin; male or female...
Not to mention SCSI cables - many more possibilities!
twocvbloke
I've used the wrong wallwart on things before now, not creating fire, but definitely releasing the smoke that all electricals run on, but that's what happens when barrel plugs are interchangeable between voltages, whether by design, intent or manufacturer stupidity...
