Bye Community!
James
Bye Community!
For a short while - We should be starting our upgrade (which hopefully none of you will notice) shortly.
I'll be back again once it's done Smiley
Re: Bye Community!
James - will you please go back to bed and stop trying to give us all apoplexy? Thought for a second that you were hopping off to TalkTalk or something equally sinister!    Shocked
James
Re: Bye Community!
I've been up since half four (in the office from 5).
We're still upgrading.
Fixes: 154
Re: Bye Community!
All finished yet?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
James
Re: Bye Community!
Yep - Should be 1.1.10 an all (4) servers.
James
Re: Bye Community!
Right - All done.
Please do let me know if any of you see any odd behaviour (Jelv not included) on the forums.
pierre_pierre
Re: Bye Community!
had this as a reply dont know what it meant
Quote from: adiewoo
I can make a hat, a broach or a pterodactyl...
James
Re: Bye Community!
Adie is normally odd.
Re: Bye Community!
That's a quote from Airplane! Now there's a film I haven't seen in a while. I'll be watching that later on I reckon.
Re: Bye Community!
Seriously, about  05:30. had message "database error" ok at 06:00.
James
Re: Bye Community!
That's probably to be expected given it was during the maintenance work Smiley
Re: Bye Community!
I expect so James, unfortunately while could get a topic heading list, couldn't open the topic, so couldn't access your post telling us there was work-in-progress. No doubt if I'd looked elsewhere (community home page for instance) I'd probably have found something.
However alls well that ends well, guessed it would be sorted in due course.
James
Re: Bye Community!
If you'd checked service status, you may have felt enlightened Smiley
Re: Bye Community!
Will file that info for further use if required.
Ta!
PS. have my browser home page as forum login page, rarely inspect the "home" page.
James
Re: Bye Community!
You could sign up for the email feed?
http://usertools.plus.net/status/email.php
