Building sites
Building sites
Like many people I'm fascinated with the goings on on large building sites. I was parked up yesterday alongside a large industrial build, watching two tower cranes operating. And I wondered that if there is a very large counter-weight to balance any object being lifted fixed to the short arm of the jib, why doesn't the whole thing over-balance backwards when there is nothing being lifted?
Fixes: 15
Re: Building sites
and how do they get it up there in the first place ! ! !....  Roll eyes
techguy
Re: Building sites
It is fascinating watching large cranes, when I moved to MK there was lots of the main office/shopping complex being built so you could see from a fair distance, never seen one erected though.
At Christmas they used to put lights and trees on them.
Re: Building sites
I'm impressed the operator can work the controls, when they're so far away from what is actually being lifted.
Do they need binoculars Smiley
techguy
Re: Building sites
I'm sure they have someone on the geound communicating by radio but you probably do need good eyesight too.
Fixes: 168
Re: Building sites
When I was a child I was told that the building was often built around the crane then that space was used as a lift shaft - any truth in this?
Forum Moderator and Customer
Fixes: 58
Re: Building sites
Quote from: shutter
This is one way
Customer and Forum Moderator.
Re: Building sites
Quote from: Mav
Well, from what I've seen (and they always seem to be putting them up somewhere in London), the lift shaft is the first thing which is constructed.
Fixes: 168
Re: Building sites
Quote from: shutter
They used a bigger crane?  Cheesy
Fixes: 15
Re: Building sites
So how did they get the bigger crane up there?  Roll eyes  Undecided
Fixes: 168
Re: Building sites
You got me there  Roll eyes
Fixes: 58
Re: Building sites
When I was a lad they used to dig deep holes, drop in the vertical stones, slide horizontal ones across the top and dig away all the soil to reveal a building.
Fixes: 168
Re: Building sites
Quote from: Alex
Yep - at that point it's called a crane Wink
Fixes: 15
Re: Building sites
Quote from: Strat
So was you there, when they discovered Stonehenge, then, Strat? Roll eyes
Lucky you ! ! !    lol
Fixes: 58
Re: Building sites
No Shutter I wasn't on that job......union troubles Roll eyes but you seem to know about it  Wink
