Boeing 777 goes up in flames
Fixes: 12
http://www.dailymail.co.uk/news/article-3227162/British-Airways-plane-bursts-flames-Las-Vegas-McCarr...
These seem to be troubling times for the flying industry...
31 REPLIES 31
Re: Boeing 777 goes up in flames
Guardian sports reporter Jacob Steinberg was on board the Boeing 777 and here he describes the rush to evacuate the burning plane
Video also here
http://www.theguardian.com/us-news/2015/sep/09/british-airways-plane-fire-reporter-describes-panic-o...
It's good everyone got out OK, with no fatalities, despite the morons who delayed evacuation by grabbing hand luggage !!
All credit to the British Airways crew, and the excellent training they undertake.
http://www.dailymail.co.uk/news/article-3229031/It-s-safe-say-m-finished-flying-Hero-BA-pilot-saved-...
The engine housing, seen from the front (elsewhere), suggests possibly a fan blade sheared off.
Pictured in the background is the Luxor Hotel, one of our favourite LV hotels, with excellent views across the Airport.
Fixes: 12
Quote from: PlusComUK
If it has, that will raise serious concerns about the safety of those engines - especially after the disappearance of MH370. You don't just disassemble a turbofan on the runway for maintenance, those things are specialist jobs that take days / weeks to dismantle and service. The engine blades are also slotted into place and theoretically they cannot come loose so if one has, then boeing have a serious problem to deal with.
Found the image, I've adjusted the shadow detail to show the damage...
Fixes: 129
Fan blade failure is designed to be a containable event. It's being suggested here http://www.pprune.org/rumours-news/567401-ba-777-fire-las-vegas.html that it's more likely a compressor disc.
In fact the last post on there has the initial results of the investigation
• Initial examination of the left engine revealed multiple breaches of the engine case in the area around the high pressure compressor.
• Examination of the material recovered from runway found several pieces of the high pressure compressor spool (approximately 7-8 inches in length).
Comprehensive reporting by the BBC
http://www.bbc.co.uk/news/uk-34213996
The most worrying aspect of this short, initial report is that it looks like the engine failure was uncontained.
If an engine breaks, the casing is designed to stop any bits of metal flying out and damaging the rest of the aircraft, including the fuel tanks and critical wiring.
Uncontained problems can be very serious.
As for the part that appears to have broken, the high-pressure compressor spool, Dr Colin Brown from the Institution of Mechanical Engineers told me that it's "most likely" to be from a "fatigue crack".
Fixes: 12
fatigue cracks, engines blowing themselves to bits through indestructible engine cowlings and planes vanishing mid flight...
It's really not looking good for Boeing is it.
I suspect they've already had several fingers pointed at them recently in light of MH370, this won't do them any good at all.
Fixes: 458
Not looking good for General Electric, manufacturers of the G90 engines fitted to the aircraft.
http://www.ntsb.gov/news/press-releases/Pages/PR20150910.aspx
Post edited with info from link.
Customer and Forum Moderator. Windows 10 Firefox 79.0 (64-bit)
Fixes: 62
If its Boeing, I aint going  Wink
it could be down to maintenance.
Possible Cause
Fixes: 12
The casing should contain any damage but spool parts, about 7-8in in length, were found on the runway.
Thrust is thrust regardless of what is around it. If you got a turbofan pushing thousands of pounds of air out the back and something breaks, it's naturally going to fly out the back with the air flow. It isn't necessarily going to fly out sideways as there is a fight between centrifugal force and rearwards thrust going on. The only way to stop things flying out the end would be to cover it up.. blocking the thrust (and the point of the engine) in the first place.
The part that appears to have broken, the high pressure compressor spool, is a circular disc that spins at very high speed.
It's designed to never break, because if it does the tough outer casing of the engine can't contain the bits of metal that will come flying out
Designed to never break? What do I keep saying about people and experience just lately. You can have the best engineers on the planet say something with 100% certainty but it doesn't mean they're right. This unbreakable thing just flaming broke!  Roll_eyes The titanic was unsinkable... and you can still see it today as a tourist.. on the bottom of the ocean floor in pieces via a specialist submersible  Roll_eyes
Investigators need to find out how new the part was, when it was last checked, and whether it broke because something hit it, maybe a bird
We all know bird strikes and turbofans are a bad mix.. but breaking the unbreakable shouldn't be possible... if anything I'd expect the bird to be a mini sliced and BBQ'd turkey as it came out the rear end.
Dr Colin Brown from the Institution of Mechanical Engineers has told me that, although you can't rule out a bird strike at this early stage, it's "most likely" to be from a "fatigue crack".
In an unbreakable part  Shocked
The critical question now, is this a one-off or is it a problem that could arise in similar engines?
MH370 was the first thing that entered my mind the moment i heard about this story.
Time to permanently ground them along with the Concord, with no scope for any replacements to fill the gap created... Grin
Why?
