Block
Block
How can I block a web site?
I have had something occur that I cannot deal with. A web site (I have not included a link for it here) has taken over my home browser page. Obviously, since I am posting this it is no problem to access other web pages. However the site defies all attempts to stop it being my home page.
I have reset several times my usual home page but each time it reverts to the unwanted web page. The page originates Israel and takes the form of a search engine. Checking the sites identity information I have blocked all available options.
It originally added a toolbar to Firefox, but was uninstalled, and now doesn't appear in the toolbar list.
During attempts to deal with it a very brief pop-up appears telling me that the site has blocked an attempt to disable it.
The site continues to set itself as my browser home page. Other than that it seems fairly harmless....so far
Anyone any ideas?
Midnight_Caller
Re: Block
Use a hosts file to Block it from calling home, then remove it.
Fixes: 127
Re: Block
I'd use your hosts file to make it point to yourself, as Garry has suggested, add the line:
127.0.0.1 <dodgy website address>
or you might be able to do it in your router.
Will Moderate For Thanks
Re: Block
Just use the free version of:-
http://www.malwarebytes.org/
to get rid of it.
Re: Block
Sorry Gary, you'll have to a bit more explicit than that. Details please...
Re: Block
@Dvorak, I already have Malwarebytes installed.
Re: Block
You have an infected PC.
Do a dns lookup to find the IP address of the offending website. If it's say fred.com edit your hosts file add it as 127.0.0.1 fred.com
That will stop it accessing its website (you should get a blank page) but not stop it from changing your home page. You then need to scan your PC with various A/V and malware scanners to get rid of the infection. Which ones have you tried to get rid of it so we can suggest others if they do not work?
Note: some infections take great length to stop you removing them. You may need to run the scanners in safe mode.
Fixes: 127
Re: Block
here you go.. http://www.makeuseof.com/tag/block-unsafe-websites-blocking-lists-windows-hosts-file/
I didn't mention malwarebytes...
Re: Block
Sorry it was Billnotben. Apologies to Bnb
Re: Block
Currently running malwarebytes.
AVG full scan didn't find it
Re: Block
Don't know if it's any help but my brother had a recent web bug effort that malwarebytes wouldn't get rid of. Until I noticed an unknown process running in the task manager.
When that was stopped malwarebytes cleaned it up OK.
Ah just seen you already have it running. In our case it wouldn't start until we stopped the process.
You could enter the dodgy url here:-
http://www.virustotal.com/
and see what it comes up with.
Re: Block
Also try spybot search and destroy
And run all your scanners in safe mode.
Re: Block
Thanks guy's, I'll get back to you. Running full Malwarebytes which will take some time. And don't believe in running more than one scan at a time.
I used to have Spybot, will give that a try as well. As I will with all the other suggestions.
Keep'm coming in please.
Re: Block
Well, just before shutting down in exasperation for the night, I thought I would try an outside chance and ran a system restore (from two days ago)
And....it "seems" to have cured the problem!! In all honesty, I didn't expect it to.
Anyone like to add anything to this or predict if it is only a respite?
Midnight_Caller
Re: Block
I would still do a full scan with:
Spybot - Search & Destroy
Spyware Doctor
Superantispyware
And Run your Anti-Virus Program
