Bing Maps problem
penneck
Bing Maps problem
If I try to use Bing Maps on my pc at work (OS = Win XP Pro), searching for a place doesn't work. Everything else seems okay - I can move the map around, I can change the scale, I can go between road maps and ordinance survey maps, but ask it to find a specific place, and it can't find it. It doesn't seem to matter where in the UK I am searching, county, town, village - Bing Maps cannot find it. Bing Maps works perfectly on my pc at home, and it works perfectly (so I am told) on a colleagues pc at work.
Has anyone on the forum had this problem, and if so, how was it solved?
