Biggest Pool in the World
Here's a couple of shots of a swimming pool that has got into the Guinness Book of Records as the biggest in the World.
It's in Chile and it is more than 1,000 yards long, covers 20 acres, had a 115ft deep end and holds 66 million gallons of water.
Re: Biggest Pool in the World
Isn't that what the sea is for? Huh
Some people prefer the safety of a pool.
It's also warmer than the sea.  The sun warms the water to 26c, nine degrees warmer than the adjoining sea.
and no dangers of tides, undercurrents to sweep you out to sea, and no sharks etc etc
With a length of 1000 yards you have to be fit to do 10 lengths Smiley
community
How do you keep such a big pool clean?
It must be full of bird droppings, all other droppings.......
Apparently it's very clean.  Its turquoise waters are so crystal clear that you can see the bottom even in the deep end.
The pool uses a computer- controlled suction and filtration system to keep fresh seawater in permanent circulation, drawing it in from the ocean at one end and pumping it out at the other.
Fixes: 247
So it's a salt water pool then... put me off a bit.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Quote from: artmo
[me=Be3G]thinks artmo is starting to sound like an advertisement...[/me]
Fixes: 247
You might be on to something there Be3G, wonder if artmo has shares in said establishment...
Presumably salt water is better for you ?
I actually prefer swimming in the sea if it is warm enough.
Fixes: 131
At 115 feet I don't think I'd want to see the bottom......vertigo Cry
Customer and Forum Moderator.
That is a monster of a hotel. Sad
3Mb FTTC
There's a natural version at Slapton in Devon
http://www.slapton.org/
but I think it's a nature conservation area - so couldn't be artificially cleaned up for cleaner swimming
pierre_pierre
and dont forget Chesil beach that 18 miles long
