Bicycles
Bicycles
Hi people,
Not the usual topic here, but I'm struggling to find a good website, forum about bicycles.
At a late age, i'm seriously looking to get a new bike, to help me keep fit and to have a bit of fun.
i want to do noncompetitive, just fun cycling on roads, and sometimes on forest / farm tracks etc - occasional relaxed touring etc so i think I need what they call a hybrid bike.
I've popped into two local shops and they recommend for example the Trek 7000 series and with a budget of about £500 for everything includinhg helmet, pannier , lights etc, it looks like a 7200 or a Specialized  Crosstrail Sport Huh.
Could anyone advice on good comparitive websites, forums, magazines to look at.
What sort of discounts do bike shops go for if pushed.
many thanks
Mal
pierre_pierre
Re: Bicycles
It is argued that a sprung rear suspension is not a good idea, a front one is.
Go for as many gears as you can, to suite your varied terain
If £500 is you budget, you can get a reasonable one for that, but Comp bikes can cost £1000's
Fixes: 226
Re: Bicycles
Hmmm...
I do enjoy my bikes, though I am into straight off roaders - I have a competition class Bianchi at the moment.
Out of the 2 that have been recomeneded to you I'd go for the specialized one, they make some great bikes. The Marin Redwood may also be worth a look too.
Sign up here http://new.britishcycling.org.uk/ for some good advice and chat Smiley
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Re: Bicycles
Agree with pierre (now there's a first) a sprung rear wheel, either by a sprung saddle mount or rear forks will absorb a good deal of the effort you are trying to put into turning the pedals. You will notice that racing (road or track) cyclists -often the first to embrace cycling innovation- do not use "suspended" frames for their bikes, front or rear. Or indeed sprung saddles, for the same reason.
