Barry the Mod's Photo
fceluk
Poll for the preferred photo of Barry the Mod iminent... Wink
Re: Barry the Mod's Photo
Well, I couldn't decide, so I thought I'd just have them randomly cycle  Grin
B.
fceluk
No offence but maybe some of them should have randomly cycled off down the street Wink
Edit: Well you did say Mods need thick skins...hope that's true Smiley
Midnight_Caller
Baz stick with your old 1, and stop trying to confuse us all.  Wink
jmd
on the floating head one which was original Barry looked olderand wiser than on some of others so think he should stick with that!
James
Quote from: jmd
I'm not so sure.  I felt that it was creating a rather false perception Smiley
[me=orbrey]has a plan...[/me]
No wait, I might not bother... I could sit here refreshing the page and watching his face change for hours Cheesy
mcgurka
I must say, I like the random photo thing though.. I find myself checking to see which one its on now!
I'll dig out the script if you like - didn't take long to knock it up.
It's a php script that spits out an image header, then picks a random image from a preset location.
Fairly simple Smiley
B.
Fixes: 158
Quote from: Barry
You really shouldn't end a post with something like that.
It just begs a response Wink
Customer and Forum Moderator. Windows 10 Firefox 63.0 (64-bit)
mcgurka
And the response is.. yes it is fairly simple!
Barry, if you could dig out the script for me, I would be much obliged!
Scott
As requested:
http://www.ablebox.com/avatar/rotate.txt
Rename to rotate.php and call as per the (yikes) documentation!
I'm actually playing around with PHP at the moment (although I'm a programmer by trade, my PHP skills leave a lot to be desired) so would be interested in critique, or suggestions.
My next thought is to automatically rescale images to a specific size - at the moment all the source images are specifically under 80 x 80 to ensure I comply with the link:rules
B.
mcgurka
Very nice scripting!
I would definately like to see resizing on the fly, although this could potentially dump a large load on the server processors. Also the error image is created at a stream of 100x100, perhaps reduce this to 80x80 to keep in line with the rules?
Perhaps a simple php upload script, to resize the images once would be an idea for it?
Theres even xss exclusion, impressive! Overall, i would most certainly rate that an A! and will be making it my own DP (if you dont mind barry) later on this evening!
A script to be proud of, good job!
In fact, barry can you send me the direct php file, notepad keeps mucking up my formatting of it! Ive pmed you my email.
Fixes: 158
Have you tried Notepad++
