BT hub 5 wifi
NorthEasterner
BT hub 5 wifi
I've just realised that my BT hub 5 has weakened the signal on both 2.4GHz and 5GHz bands.
For instance in the kitchen i'd get 5 bars now I only get 3, the same in the living room/lounge
When i'm in the same room as the router its full bars but when I leave the room to the opposite room it drops wifi.
Used to be very strong throughout the house.
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
TORPC
Re: BT hub 5 wifi
Check to see if it called home for an update
Fixes: 126
Re: BT hub 5 wifi
have you tried telling it off?
Will Moderate For Thanks
TORPC
Re: BT hub 5 wifi
Grin Grin Grin
It may be ill and need a trip to the Vets Cheesy Roll eyes
NorthEasterner
Re: BT hub 5 wifi
No it hasn't updated itself.
Although the bt wifi has disabled itself.
On the phone to india now, to get a replacement, as channel changing didn't help
TORPC
Re: BT hub 5 wifi
Let us know if the cowboys send you a replacement Wink
NorthEasterner
Re: BT hub 5 wifi
They said NO as they couldn't see the problem on their side.
Tried the basic troubleshooting steps and they said I have to monitor my connection for 3 days to see if any change.
I'll doubt i'll get another free hub 5 off them.  Undecided
I don't have my old one so don't ask
