BT Wiring Curiosity
Fixes: 131
BT Wiring Curiosity
Just curious really but...
The telephone cable to my house goes into one of these
and then straight into one of these
I was just wondering where the demarcation line was as they are both BT items.
Customer and Forum Moderator.
198kHz
Aspiring Champion
Fixes: 11
Re: BT Wiring Curiosity
Is the first photo an example, or the actual block in your house? I ask because there should be only two wires going into the master socket.
Remember you are unique - just like everyone else
Well technically they both do the same job, except the lower one has a jack socket, which I think equated to the right side of the upper junction box.
Nice colour carpet Strat!
Fixes: 131
Quote from: 4Candles
They are both examples.
@Petlew Not mine....I daren't remove mine from the wall as it would probably disintegrate.
The connector not the wall. Embarrassed
itsme
Interesting one! The master socket and the terminal box belong to BT. The cable from outside going to the terminal box belong to BT. The cable between the terminal box the the master socket can be classed as internal cabling and this belong to ....?
that top connector box is ancient.  i remember shuffling telephones about and how easy it was and then along came the stupid square boxes you need a special tool for attaching the wires.  saved the fitter time no doubt.
Fixes: 12
Quote from: artificer
Yup!  But there are still a lot of them about in older premises!  BT do not usually rework the internal configuration unless they have to (or the coffee and chocolate biscuits are liberally dispensed)  It's a real problem trying to get to the bottom of an ADSL problem when the internals just end in  one of the top rectangular boxes.
pierre_pierre
I agree but some of us are lucky, got one of those and physically I cant get a better synch - 8128
Fixes: 131
I did say they aren't my boxes.............jeez I'm going to have to take a photo when I get home now Roll eyes
I'm syncing at 7 1/2ish but my profile is 5 1/2 Roll eyes
Quote from: Strat
At the Test Socket behind the removeable faceplate on the NTE5A.  Wink
Fixes: 131
That's what I thought Sad
nadger
Our house was built in mid 1970s and until recently had GPO cover plate in hall - replaced now by NTE5a.
Still got one of the connectors, picture one, in lounge - not going to crawl under furniture to see what's on the front. It's part of what were hardwired extensions.
pierre_pierre
be this the answer
pierre_pierre
this is mine, but it does go to a standard single socked, fitted years later by BT
Lurker
Do you have a larger copy P_P?
Hard to see exactly what you have connected, and there's a pretty reasonable chance that you could improve things with the judicious application of a pair of sidecutters (or a screwdrver if you prefer).
