BT/Plusnet
dennisb66
BT/Plusnet
Have just read on another forum site that Plusnet is part o fBT,is this correct? Huh
Fixes: 174
Re: BT/Plusnet
Correct at the time of writing.
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Fixes: 348
Re: BT/Plusnet
A wholly owned subsidiary no less.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
nadger
Re: BT/Plusnet
One of the reasons I joined them - got fed up with Pipex continually changing hands.
Re: BT/Plusnet
http://www.plus.net/press/about_us.shtml
In January 2007 we were bought by BT. Now we run as an independent subsidiary from our offices in Sheffield. There are more than 200 of us working here and in 2008 we were awarded a ‘First Class’ one-star rating in the annual Best Companies to Work For survey.
Fixes: 10
Re: BT/Plusnet
To clarify: Plusnet is owned by BT Retail.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Re: BT/Plusnet
And they buy transmission,  ADSL, and telephony  services from BT Wholesale !
pierre_pierre
Re: BT/Plusnet
and get the cables repaired by BT Openreach  (all the above separate companies)
Fixes: 9
Re: BT/Plusnet
Just out of interest if I switched provider from plusnet to BT would I get the same service in terms of speed & support but pay more for it ?
Fixes: 62
Re: BT/Plusnet
speed - almost certainly  Grin
service - most unlikely  Sad
Re: BT/Plusnet
Yes, you would pay more.
haggis
Re: BT/Plusnet
Quote from: gleneagles
Firstly Hi all Just back from BT
If you switch from Plus to BT beware the suport is terrible.Unless you use one of the home hubs (which I and a lot of others found rubbish) the Indian helpdesk fob you off with anything in the hope you disapear. Speeds are fine or at least mine are/were and at £130 a quarter for broadband and phone with anytime calls I say it's dearer over there .Seriously For my one and only fault as in no speed whatsoever I ended up using the cceo email address to get it fixed .India repeatedly told me there was nothing wrong it was my equipment or do many speed tests the line will reset etc ,It turned out to be a fried card in the exchange.Only took 5 weeks .Out of Plusnet ,Nildram and BT the only one have ever had problems with was BT .also they advertise an unlimited BB at £25 or so it is in effect 80GB or less and you get the warning But saying that I only ever got it once and that was because I dropped my usage thinking I'll never use that much.Depends on what you do really most ISPs will kill speeds for something such as P2P and I do believe some of th eP2p stuff is legal .
Also if you are having issues on a plusnet line then you could well still have the issues on a BT connection .It's really swings and roundabouts.Personally I avoided BT helpline as much as humanly possable.
nadger
Re: BT/Plusnet
A former neighbour had BB with BT and popped in to ask if I could help with a problem he was having. He'd made numerous calls to Indian call centre and had received no help whatsoever.
Knowing the chap was a BT pensioner, who'd taken early retirement, I asked if he knew anyone in his former office, at MK,  who dealt with adsl.
It appeared that chap who'd been on next desk to him did so I suggested the obvious and next day there was an Openreach van outside his house and problem was fixed.
T'aint what you know etc etc  Wink
