BT Broadband Checker Broken.
Fixes: 317
Just put my number in here http://www.dslchecker.bt.com/adsl/adslchecker.welcome and it tells me this....
Welcome to the Broadband Availability checker. This will provide a provisional check of your ability to receive reliable Broadband services.
Please enter your telephone number.
There is no data available for this number. This could be either because it is not a BT line or it is a new BT number that has just been provided. Most new numbers will appear on the checker 24 hours after BT has installed the line.
Well I've only had this line and number for 20 years Undecided
Customer and Forum Moderator. Windows 10 Firefox 69.0.3 (64-bit)
Life is tough enough without adding Linux into the mix.
13 REPLIES 13
Re: BT Broadband Checker
Looks like its broken, I get the same.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
David_W
Me too, but I'm with PlusNet for my phone rather than BT.
/edit -
Please enter your postcode.
Sorry this postcode has not been recognised by this checker, this could be because this is a new address with a new postcode that has not yet included in our database or the postcode does not align to an exchange area. Therefore, can you please try again using your telephone number or address.
Maybe the internet is down?
Fixes: 62
Re: BT Broadband Checker Broken.
That is because you have all been moved to Plusnet LLU and they didn't tell you  Grin Grin
Fixes: 317
I've been with PN for my phone service for quite some time but have done many checks with the above service since.....it's broken.
@Jim I thought I'd been cut off Shocked.......and don't go restarting the PN LLU rumour Roll eyes
Fixes: 27
It is definitely up the creek...
I put my number in and got the same result as strat..... so I decided to use the postcode checker....
Please note that the postcode checker is less accurate than the telephone number checker because it uses a best guess of where you live
so I continue... and enter my post code...
anniesboy
Its working for me ,my phone is with PNet
Fixes: 10
Working for me for both of my lines.
NB The checker is from BT Wholesale. Plusnet and BT Retail both use BT Wholesale to provide telephone and broadband services, so whether your line is with Plusnet or not is a total red herring!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 317
Looks like they've now fixed it. Smiley
Your exchange is ADSL enabled, and our initial test on your line indicates that your line should be able to have an ADSL broadband service that provides a fixed line speed up to 2Mbps.
Our test also indicates that your line currently supports an estimated ADSL Max broadband line speed of 7.5Mbps; typically the line speed would range between 6.5Mbps and 8Mbps.
Still no return of the ADSL2+ date which is what I was looking for in the first place Cry
Fixes: 62
Not for mine they haven't
Fixes: 317
Maybe they haven't fetched you back off LLU yet Tongue
Fixes: 62
I thought they had as my noise margin dropped back to normal
Fixes: 27
Hmmm,.... Interesting.... I just did another check.... and first time it was as originally reported by strat.... so I used the "back" button at top, and then clicked on the submit button, it then showed the "correct" answer.....
Roll eyes
Fixes: 62
Now works after a fashion
Your exchange is ADSL enabled, and our initial test on your line indicates that your line should be able to have an ADSL broadband service that provides a fixed line speed up to 1Mbps. However due to the length of your line the 1Mbps service may require an engineer visit who will, where possible, supply the broadband service.
Our test also indicates that your line currently supports an estimated ADSL Max broadband line speed of 1.5Mbps; typically the line speed would range between 1Mbps and 3.5Mbps.
Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 2Mbps; typically the line speed would range between 1.5Mbps and 4Mbps. Our test also indicates that your line could support an estimated ADSL 2+ Annex-M broadband upstream line speed of 500Kbps and downstream line speed of 500Kbps; typically the downstream speed would range between 250Kbps and 1.5Mbps.
Just for the record I am not on ADSL2+
