BBC tells ISPs to get stuffed
Fixes: 21
Re: BBC tells ISPs to get stuffed
sub-titles........................... which I find useful in "action" movie
Bang! Bang! you`re dead pierre  Grin  Grin  Grin  count to 100 and then you can join in again ! !  Roll eyes
pierre_pierre
OK I count quick
Denzil
Quote from: axisofevil
Why do people stream BBC content?
Even off-peak, you get an inferior picture, with artefacts present (full-screen).
It's much easier to do a download and play it back 5-10 minutes later - and you get a much better picture.
However, either picture is inferior to broadcast quality or even VHS quality, so it's probably a temporary fad.
Because downloading is only possible if you use XP or Vista. Not everybody is behoven to M$!
pierre_pierre
I dont like iPlayer, but I think that you can now use Mac and possibly Linux, but not sure
dgdclynx
I use iPlayer continually to get BBC4 programmes otherwise unavailable to me. And I do prefer watching them in the morning. I download.
pierre_pierre
If you cant get BBC4, what are you going to do when the cut off Analogue?, you can now get a freeview tuner for less than £20 Cool
VileReynard
All Star
Fixes: 11
Quote from: pierre_pierre
... you can now get a freeview tuner for less than £20 Cool
Plus the cost of the new extra-expensive aerial, which is almost certainly needed.
Unlike analogue, digital doesn't degrade gracefully in weak signal conditions.
pierre_pierre
True, my self installed antenna cost more than the tuner  Crazy
dgdclynx
Re Analogue. When they replace the current Analogue booster station by Digital in 2010 I expect to get Freeview, although it may be a cutdown version. I am not keen on getting a satellite dish.
Hence why I am a Sky customer: A years subs to Sky costs less than the cost of an aerial upgrade in these parts plus two freeview boxes.
After y1, I can have satellite freeview ongoing...
Also, cost of y1 subs is only marginally more than the setup/installation of sky freeview.
dgdclynx
I had to get an engineer to repair my aerial a couple of months ago and he said our local aerials wouldnt need upgrading for Digital when it came.
Which is fine if you have an aerial - if you don't however, you are more than a little stuck!
Dunno why I included the word 'upgrade', since we don't have an aerial at all! The housebuilders decided not to bother, since they need to be on poles more than 8' above the roofline to get a signal. Sad
Most folks have satellite or cable where I live.
James
Yup, my parents had to pay about £400 to get Freeview to work.
They can't get Sky because of the trees overlooking their front driveway.
alanf
iPlayer has its uses but is no substitute for a PVR. Many programmes are not made available on iPlayer, downloaded programmes can only be retained for a month (or 7 days after you start viewing them), and it quickly eats up my download allowance unless scheduled for after midnight. I do use it occasionally though when I fail to record a programme that I am interested in. For example I tried twice to record Click but each time something else was transmitted instead so I watched it on iPlayer instead.
It is now possible to stream programmes on MAC and Linux but not to download them. The BBC relies on Microsoft software to ensure that downloaded files are not retained longer than rights allow.
alanf
Quote from: Denzil
As the picture quality is inferior the amount of information streamed is less than that downloaded and therefore uses less of ones allowance. Also, more importantly, downloading programmes requires the installation of Kontiki P2P software. So, unless one is very careful, one can find oneself paying to upload programmes for other viewers as well as for downloading for oneself.
