BARGAIN OF THE YEAR..throw razors 13p!
kdoug007
was  in me  local  tesco last  week  and  was  fed up  paying £5+  for  throwaway  razors,,,
  So    saw a  pkt  of  5  for  13p..!!!
well i  tried  them and  WOW... im  so impressed  ,,  1  razor  have  used 3  times  so far  and  its  fab!!
  So i  went  back and  bought  3  more  pkts!
Fixes: 10
Re: BARGAIN OF THE YEAR..throw razors 13p!
Gotta be honest I kinda like Tesco razors too. I bought their shaving razor with disposable heads several times and it's always been very good.
I then tried the sainsburys version... OUCH! I won't touch that again - very rough, kept cutting me etc oh and it cost MORE than the Tesco version.
Fixes: 16
Never used `em.... !
I use a phillishave 3 rotary head shaver...(rechargable) . had it about 10 years, cost about £50 , never had any problem with it... £5 per year.... divide by 365.... about 1.37p per day.... !...
Oh and I accidentally dropped it in the bath, whilst using it.... (not plugged into mains)... and it was still running under water.... got it out... shook out some water.... left it 24 hours on the radiator, and it still works as good as new !.. Yes.... it still recharges ok, too ! !
James
I don't think you have factored in the recharging costs.
Fixes: 10
Trust James to think of that  Grin
kdoug007
just to add,,  with the  packet of  5  rqazors  13p..  ensure  the  shave  foam is    rich,,,,
  the  blide    then  glides  over  the  skin,,,,,
    so far used the  blade  3  times..  perfect
Fixes: 58
Quote from: Jameseh
I don't kdoug007 factored in the shaving foam cost either Wink
Customer and Forum Moderator.
Fixes: 9
Think I will stick with the Aldi triple blades (5 per pack) True the  cost just over £2 per pack but give an excellent shave and last a fair while  Smiley
Fixes: 16
Quote from: Strat
Quote from: Jameseh
Recharge once a week...... say 25p?
Hot water and water rates also not factored into the "wet shave".....  Undecided
Razer
Has anybody factored in the time costs? Cheesy
Makes me glad I've got the bushiest beard. It costs nothing to maintain and only requires the occasional combing.  Grin
Fixes: 58
I once grew a beard but the moustache looked ridiculous, more like an overgrown scrubbing brush, so off it came.
Fixes: 168
Just before Christmas I bought a promotional pack of 20 Gillette Mach 3 blades with razor for £20.
As I only shave around once every 7 days or so (sometimes even less) and get around 4 shaves a blade they should last well into the second half of 2014 Cheesy
I estimate that's around 38p a shave including hot water and gel.
Forum Moderator and Customer
Fixes: 10
Heh, I don't even use razors often to be honest. I'm skint and can't really afford them so I go with the stubble look instead. My electric shaver is knackered but the sideburn trimmer isn't.. use that all over your face / neck and it cuts everything to stubble length (and even thats once a week at the most).
Job done  Cheesy
