Avitars, squares & circles
Fixes: 9
If you draw a square and put a circle in the square with the edge of the circle touching the sides of the square what percentage of space is left if you remove the amount in the circle ?
Is this figure the percentage of space we have lost when the Avitars were changed to circles ?
rongtw
Fixes: 12
Re: Avitars, squares & circles
Its not a circle avatar ,,,, its a SMARTIE Grin
Or is it the percentage of members that moved to the new forum?
Fixes: 168
I make it 21.5%.
Assuming the square is 2x2 then it's area is 4
the radius of the circle would be 1 so it's area would be Pi*r^2 =3.14 (2 decimal places)
Area lost would be 4-3.14=0.86 Which is 21.5% of the square's area.
Happy to be corrected if my maths is wrong.Wink
Forum Moderator and Customer
198kHz
Seasoned Pro
Fixes: 9
Happy to agree that your maths is correct.  Smiley
Papyrus and Comic Sans walk into a bar. The bartender says, "Get out -- we don't serve your type."
Fixes: 10
Mav wrote:
I make it 21.5%.
Do you think we can get our subscriber fees reduced by that to make up for the loss? Wink
Fixes: 9
Or some compo for the damage done to our avitars with 21.5% chopped of them ?
Grin
Talking of percentages eBay look like they are considering a fee rise to 12%.
That would really screw the pooch as 10% is already too high.
That said the same applies here with every line rental rise.
Eventually a cut off crash point will be hit and the bubble will burst.
