Automatic compensation
This is interesting but PlusNet are joining later
http://www.bbc.co.uk/news/business-41940505
62 REPLIES 62
Fixes: 12
Re: Automatic compensation
How come Plusnet joining later ?
Next year or later are they waiting for new billing system? First 😕
Seasoned Pro
Fixes: 4
Just been reading about this, I wonder what other ISP's think about it. Bit it does make you wonder why Plusnet joining later, surely it should count for all at the same time.
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
Fixes: 12
In terms of implementation, Ofcom recognises that introducing this will be very complex and that ISPs need time to adapt their billing systems, online accounts and call centres. As a result there will be a 15-month implementation period before it comes into effect during early 2019.
he new scheme is actually based on a voluntary proposal from the industry, which has been put toward by BT, Virgin Media, Sky Broadband, TalkTalk and Zen Internet (Plusnet and EE have also indicated they will join the scheme). In other words, Ofcom has decided not to impose a regulatory system but they will review the new approach one year after it has been implemented.
https://www.ispreview.co.uk/index.php/2017/11/final-details-automatic-compensation-serious-broadband...
Fixes: 62
It will probably come into effect after the new accounts system Crazy
Seasoned Pro
Fixes: 4
Only a couple or three years to go then, (maybe).
Fixes: 12
I can see two sides to this:
One on the one hand, if there is a fault then a user should not have to pay for a service which the ISP cannot provide.
On the other, the ISP paying out will mean price rises which will affect people who are lucky enough to not have faults, or rarely (like me).
Fixes: 12
Main thing is will this make BT/OR improve ?
No they will just incerease prices Lips_are_sealed
Fixes: 12
Exactly @rongtw
I think your second line of your post is the correct one sadly.
Fixes: 15
Customers will have to phone up initally.......
All our lines are busy at present......try again later.
Wink
this can only be a good thing and not soon enough
at the moment there is nothing i as a customer can do to get a fault fixed
the 3 companies involved ie plusnet/btwholesale/openreach all use each other to shift responsibilty
i have had 1 fault in some 15 years and the way plusnet have treated me has been appauling
there is nothing to make them fix my fault and they have had me in a no way out workflow, including many pointless engineer visits
note that btwholesale block engineer call out types that the openreach engineers recommended i ask for
and instead only allow home type visits even though everyone involved knows that it not a problem at my house
and is just a way of causing maximum inconvenience to try and make me give up
well once the auto compensation comes in plusnet will have to start fighting for things to get fixed rather than at the moment where they just shrug and tell me to go elsewhere
the other thing about this is that offcom have clearly stated what they think reasonable compensation is
so on my current fault open since august will now be running into something like £700 at £8 a day
quite why we have btwholesale between plusnet and openreach i do not know
so all in all it's quite obvious why plusnet will drag their feet on this, but just because it's not currently automatic doesn;t mean it doesn;t have to be paid at all ( was interesting that only 15% of compensations are paid right now )
i for one after the way i have been treated will be demanding proper compensation for what has gone on in my ongoing fault
no the rate of £8 a day will not be absorb able they will have to start sorting out the problems that they have
plusnet will no longer be able to play the waiting game, they will have to start going after btwholesale/openreach to sort issues out
right now none of the 3 plusnet/btwholesale/openreach have any incentive to sort tricky problems out
the likeliest negative response i see is that they will try and refuse to accept faults, but in the end that will get attacked as well
and the current shady practice of for example how many disconnects a day is acceptable which is hidden will be exposed just like the max speed etc
Fixes: 9
£25 for a missed appointment is fine if your take-home pay is £3/hr or less (which is illegal), otherwise you are still severely out of pocket.
That sounds very familiar..... Angry
I continually insist the fault I've had (for +7 months) is not the fault of PN, but it's incredibly frustrating that BTW and Openreach seem to be passing it back and forth with no real outcome or timescale to fix.
It's amazing that the industry get away with it, largely because there is only one main player in FTTC with everyone else kneeling in front of them asking for connections to "their" network, yet when a fault develops they simply don't take responsibility for it.
I honestly feel sorry for the PN support team who are hitting their heads against the proverbial brick walls every day.
But isn't it true, to all intents and purposes, that plusnet already get automatic compensation.
They just don't automatically pass it on to the customer.
