Aurora possibility tonight
Fixes: 188
Re: Aurora possibility tonight
Sadly I have a south facing property and due north of me is the light polluting city of Sheffield so not much chance of a sighting even if the cloud cover clears. Sad
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Fixes: 21
According to this page....
http://www.softservenews.com/Aurora.htm
The aurora, (if present) will only be seen in the north of scotland....
(Scroll down to the REAL TIME AURORA FORECAST MAP  and click on the linky...  (Here's a larger, high resolution image in case you need it.)  and you can enlarge the pic  to see the aurora is only just above northern scotland....
Also... the Kp number is forecast to be 4 at about 21:00 if you click the right hand European map and check where the Kp number is , ( along the green line ).. and see how that is in relation to your location, is to show whether you are likely to see it.....
