Are you being blocked?
Midnight_Caller
Hi All
Is your web site being blocked?
One of my site's is being blocked by TalkTalk,  Shocked  Angry  test your site's out and see if your site is being blocked!
The site that TalkTalk is blocking is: www.ebook-heaven.co.uk and if you go to it all that is on it at the moment is:
Back Soon
up dating web site
Sorry for any
Inconvenience
It has been like that for over one year.  Huh
Re: Are you being blocked?
Why do you say TalkTalk is blocking it?
I get the same message from my connections in other countries...
Fixes: 260
same here, there's nothing blocking it..
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 20
Perhaps TalkTalk's filters are mistakenly classing it is a dating web site - which might be blocked by an enabled by default family / children suitable content only filter. Maybe remove the space between the words up and dating?
Midnight_Caller
@AndyH, and @dvorak
If you can see:
Back Soon
up dating web site
Sorry for any
Inconvenience
Meens your ISP is not blocking the site, if you were with an ISP that is blocking ebook-heaven you would not see that message on the site.
Results from https://www.blocked.org.uk
http://www.ebook-heaven.co.uk
ISP         Result         Last check on               Last blocked on
AAISP   ok                2014-07-03 19:51:41        No record of prior block
BT           ok               2014-07-03 19:51:41     No record of prior block
EE           ok                 2014-07-03 19:13:12     No record of prior block
O2           ok                 2014-07-03 19:13:08     No record of prior block
Plusnet   ok                 2014-07-03 19:13:13     No record of prior block
Sky           ok               2014-07-03 19:51:41     No record of prior block
TalkTalk blocked        2014-07-03 19:51:41     2014-07-03 19:51:41
Three ok               2014-07-03 19:13:12     No record of prior block
VirginMedia ok       2014-07-03 19:51:41     No record of prior block
Vodafone ok       2014-07-03 19:13:11     No record of prior block
Fixes: 260
I'm using a VPN with various exit points around the world and my PN, mobile and work connection... all of them give the same page.
can't see on that site where it gives that message if it's blocked either.
Fixes: 20
Try scrolling down the page?
Here's a screenshot of the results for checking a different website, screenshot taken of an extra tall window.
Fixes: 260
yeah I saw that...think I misread his post :/
