Are you an Innie or an Outie.
Minivanman
Aspiring Legend
Definately an Outie... unless I want to annoy the Mrs. Roll_eyes
Don't limit the friends you haven't met with arguments you'll never have.
24 REPLIES 24
billnotben
Re: Are you an Innie or an Outie.
Outie toilet roll.
Innie kitchen roll.
Mav
Fixes: 431
I don't care as long as there's some thereCheesy
Forum Moderator and Customer
Jonpe
Fixes: 9
I use Andrex, it's only favoured by puppies so no need to worry about the cat.
Champnet
Champion
Fixes: 7
Neither....
Minivanman
Aspiring Legend
Well we are now almost outie, so off to do some shopping before the 5000 decend on us t'morrow.
So you're a stand up then @Champnet? I have a shelf behind my toilet and if I have a roll of tissue there it invariably moves as I try to grab it, so I'll front load the holder at the first opportunity.
Champnet
Champion
Fixes: 7
After a couple of years with a messy stoma, toilet rolls are on top of the cistern (modern type) where I can get my hands on them....
Fixes: 73
Deffo 'innie' - it helps the weight of a 'fullish' roll to hold it steady so you can give the sheet a good tug to get it off.
Minivanman
Aspiring Legend
Ah those were the days.Wink
gleneagles
Fixes: 16
Hang on....are you telling me there are no automatic toilet roll holders......can't be long before we see one.
Toilet paper.......what for ?
What you need is one of those toilets made in Japan, toilet seat is warmed to your liking, when finished a warm spray of soapy water is squrted on (consored) followed by a blast of warm air.
I thought most of you guys were ' techies' and would have one of these installed by now.
Cheesy
We are born into history and history is born into us.
@Champnet, I've just read this article on the BBC have you seen it?
Fixes: 73
Cheesy
@gleneagles
I've not seen an automatic one - yet - and like you, I'm a bit surprisedWink
Never used one of those Japanese loos', but I'm not convinced they are that good. They may squirt & dry, but do they polish?
Champnet
Champion
Fixes: 7
Thanks @jab1 , yes I had read it.  She's right, simple option, live or die. There a few psychological issues to sort out such as dealing with the mess.  Once you accept the mess your dealing with was actually part of you moments ago then it gets easier.
It's hard enough polishing the buttons on a uniform never mind any other type.
