Arctic sea ice at a record low
Fixes: 10
Although we have had a very cold December, some places have had an very unusually warm December leading to a record low growth of sea ice in the Arctic.
Full details: http://nsidc.org/arcticseaicenews/2011/010511.html
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 131
Re: Arctic sea ice at a record low
It's that stupid jet stream getting lost on it's way across the Atlantic.
Customer and Forum Moderator.
Fixes: 10
That explains our cold spell but not
Air temperatures over eastern Siberia were 6 to 10 degrees Celsius (11 to 18 degrees Fahrenheit) above normal in December. Over the eastern Canadian Arctic Archipelago, Baffin Bay/Davis Strait and Hudson Bay, temperatures were at least 6 degrees Celsius (11 degrees Fahrenheit) higher than average. Southern Baffin Island had the largest anomalies, with temperatures over 10 degrees Celsius (18 degrees Fahrenheit) higher than normal.
we are living in interesting times.  critters are falling out of the sky; fish are littering beaches; whales are beaching themselves; some places are awash; others washed away.  we're having a high old time.
time to go look at the footings of various dams, methinks.
Fixes: 131
As I understood it that same jet stream first travelled north carrying milder air to the northern Canada and Greenland areas before dropping down to Europe.
This is a major shift in it's normal route and a cause for study.
Fixes: 247
gosh a whole 34 years of recorded data!!
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 10
I'd like to see a chart showing when the hottest, coldest, wettest and driest month on record for each of the 12 months (obviously excluding the driest for the summer months). Statistically those potentially 48 events should be evenly distributed over the 100 or however many years it is the records have been going. If a significant proportion of those are during the last decade say it would demonstrate that the climate is becoming more chaotic.
Quote from: adiewoo
Yes! in terms of solar activity, age etc. probably a fraction that is either infinitesimal or unmeasurable. No doubt one of the forums mathematical genius's will work it out for us
Are the wind farms blowing the airstream up and over? got to be a man-made reason for it eh!  Roll eyes Roll eyes.
Remember El Nino of a few years ago?
Fixes: 62
This is why
and this gives more detail of the reasons
Fixes: 62
I wonder if there is an oscillation  here or it is due to the well known fact that feet get colder than heads  Grin
Taken from http://nsidc.org/data/seaice_index/images/s_plot.png
Fixes: 10
I'd feel happier if that balanced the Arctic loss of -3.5% per decade!
