Appearances
Appearances
Comparisons are often of made of the similarities between Blair and Cameron. But is it just me or, does anybody else notice the same about Blair and Obama?
1 REPLY
Fixes: 62
Re: Appearances
Other than the fact that they both have permanent sun tans - apologies to Sr Berlusconi  Embarrassed
