Anyone used speedof.me?
Fixes: 21
Looking for a speedtest that didn't rely on flash, unlike most of them.
Came across http://speedof.me uses htlm5.
Tested speed seems much the same as what I was getting with speedtest.net etc.
11 REPLIES 11
nadger
Re: Anyone used speedof.me?
Just tried it and my results look accurate  Smiley
Fixes: 11
Interesting, just tried it on a tablet and got the message firefox crashed ?
Other speed checkers I use seem to work ok
St3
Aspiring Champion
Fixes: 5
Tried it on chrome worked fine really smooth Smiley
Speeds about 60% of Speedtest.net for me on IE11!  Shocked Sad
Geoff,
York.
Fixes: 12
Actually I think thats a pretty cool site!
These are my results:
Speedof.me
Speedtest.net:
So there is a little difference between the two but they are reasonably similar. I got fed up with speedtest.net a while ago as their flash wasa bit glitchy and sluggish and i always felt it was a bit iffy. I think i'll start using speedof.me from now on - thanks HB!
7up
Fixes: 29
Can someone explain to me why the "sawtooth" effect on the graphs.... also represented in the speed fluctuation on other speed testers.
speedof reported my current speed as 5.56
MBB reported my current speed as 5.54...
so pretty much the same....
nanotm
it gave me 12 down 3 up, for comparison okoola gives 60.82 down and 16.39 up and btw gives 62.22 down and 16.24 up, okoola and btw both give a latency of 16 whilst speedofme gave latency above 30, I suspect there is a problem with it only giving accurate data to none fibre customers like so many other speedtesters out there /
Fixes: 62
works for me on fibre
rongtw
Fixes: 12
yes its a bit iffy for me , sometimes same as TBB or speedtest    but some test are miles away
pwatson
The sawtooth effect is because the test is downloading/uploading increasingly larger files.  This initial small files don't saturate the link so don't report full speed.
Still S H one T for me. Don't think I'll bother again!
Geoff,
York.
