Anyone else see the paradox here??
Fixes: 13
Re: Anyone else see the paradox here??
This is the latest "food fad"    "pulled"  .... not sure exactly what it means... BUT.. to my mind it is  just all the bits and pieces that are stuck to the bones being "pulled" off and sold as "trendy" food to maximise profits...
Also the "legend" on that pic is technically wrong... it may well be taken home quickly,... but it is actually " taken home .... in this bag  " !    Cheesy
Mayfly
yeah, 'pulled' refers to shredded. I think you do it with 2 forks.
I was actually thinking  'How can it be new AND original'?
Surely they are mutually exclusive. It is either new or if there have copies of the new then it warrants the 'Original' title.
nanotm
its like all marketing though low on intellect and high on buzz words, pulled pork refers to the way you separate the meat from the joint after cooking, the same could be used by the term pulled chicken, but it probably means something ichy like mechanically separated meat does in this instance from a processed food joint that doesn't care what sort of offal is being served up so long as its got the right flavourings and doesn't look like raw tripe ....
Ready "pulled". Better to "pull" it off yourself. At least then you can see where it's coming from.
This process is used to cover up the meat nobody wants.
The meat from giant mutant deformed chickens. Smiley
