Any One Used Net Flix??
kdoug007
ok i  got my  grubby  hands on a  apple  tv  3..
  And  have a  free  1  month  with there  movie  service,,,
I  have  a  PN  WI-FI  connection  and  infact  home plugs  also ...
BUT!  either  way  i  still find  the movies..( although  a great  selection)
NOT  in 1080hd.  although most  movies  say hd...
  other  channels  like  you tube  , podcasts,,  are  all    just  fine...
dccrepairs
Re: Any One Used Net Flix??
I used netflix ALOT but never on the apple tv 3 I use the ps3, I know netflix only used to stream 720p to apple tv but unsure of the stream now
Fixes: 341
Netflix does support 1080p according to this http://ukirelandblog.netflix.com/2012/03/integrated-itunes-sign-up-1080p-hd-on.html, but I've never used it I can't tell you if it is or not.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
LukeAger
I have Apple TV 2. I couldn't say what exactly the quality of display is but its deffinatley not 1080. I now watch it through my Xbox as I get a better picture. The menu is better, and also with a little tweaking you get more content. I really like Netflix on the Xbox and would recommend using that UI if you have one.
I use Apple TV mainly for streaming to my TV from my home computer and airplay.
kdoug007
luke i dont have  x box... you mentioned  Menu..  but  i  thought  netflix  have there own  movie  menu?Huh
well it  does  when i click on  netflix...
 the  way im watching  net  flix.. is  the  wi-fi    from my PN Router  direct  to the apple  tv3..
 as  said  i also have  home  plugs    so  tried that  with  the  ethernet  into the  apple  3.. picture    quality is  the  same..
 i  would  suggest   Not   1080hd.....  go to  vimeo  or  podcast  abd  it  is  1080hd,
kdoug007
hiya  a  update...  well i solved the  problem!!!!!
i went on to my  net-flix  account    AND  saw a  section    caled "My Video"
  there  were infact 3  settings..  so i  changed  this to BEST!!
the  result  is the picture  quality  is  now  outstanding...
