Any Nine Inch Nails fans on here ?
This is surprisingly amazingly brilliant  Wink
http://www.nin.com/strobelight/
Fixes: 5
Re: Any Nine Inch Nails fans on here ?
yeah  Smiley
I love:  " Your files will arrive as windows media files playable on quite a few players with your name embedded all over them just in case you lose them. "
Kelly Dorset
Broadband Service Manager
TORPC
Looks like #Kelly hammered it Cheesy
It has recovered from the hammering, quite quickly Wink
Fixes: 10
Bit too long for me personally, i know my luck as soon as i hit em with the hammer they'll bend cos they're so long  Wink
Shorter nails are way better...  Cheesy
Fixes: 58
I have a box of 2" x 10 gauge Pozidrive screws I'm quite fond of Embarrassed
The Hand That Feeds sounds like a good solid track though.
Customer and Forum Moderator.
Fixes: 15
Quote from: 7up
Strat is the expert here ! !
TORPC
Who keeps hitting the nail on the head ?Huh
Fixes: 10
Never been a big fan of pozidrive myself, i find them annoying and easily confused with the traditional crosshead.
Too many times I've put a pozi driver in a crosshead screw and then rounded it out... very annoying.
TORPC
@7up
That is so easily done, therefore they should harden the screw heads Cheesy
Fixes: 58
I always check the fit before applying torque....but that's just me Wink
