Another...
Fixes: 192
Another...
...quiz.
Are you tech savvy? Take this  quick test.
It's not only the start of the new school term this week, it's also the first year in which children as young as five will be taught the new computing curriculum.
The updated curriculum has been designed to put a stronger emphasis on 'essay writing, problem-solving, mathematical modelling and computer programming' - and primary school children will be taught how to code.
Network operator O2 has created an interactive quiz to test your computing skills, and see if you could handle the latest education changes.
Forum Moderator and Customer
Fixes: 189
Re: Another...
level 4..
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Re: Another...
Level 4 (I got two wrong Sad )
Fixes: 189
Re: Another...
0 wrong Wink
Fixes: 192
Re: Another...
Oops - forgot to mention that I got two wrong from not reading the questions properly Sad
TORPC
Re: Another...
Fixes: 10
Re: Another...
I got 14 / 16 however technically it should have been 15 as their question about an array has an incorrect answer.
Their answer is that an array is a list of objects that are the same type and size. This is incorrect.
An array can be a list of different objects and sizes. It could be a list of strings - of varying lengths (and thus sizes), it could be a list of different types of objects, some elements could even contain other multidimensional arrays. I opted for the appropriate option and was marked incorrectly.
In object pascal for one of my server projects I use an array to keep many different descendants of TObject in - from TClient objects to TLists - all in the same array.
Fixes: 17
Re: Another...
I think for arrays, in the case of strings or objects, the array itself would just be a list of pointers (memory addresses). The pointers are all the same type and size, but what they point to could be different lengths, or for objects you would need to "cast" the generic pointer to one that points to a more specific type of object. That would be for C and C++ programming languages at least. In C a string is just a null terminated array of characters anyway.
Re: Another...
I've got problems..I can't even find the quiz. Link takes me to story but no quiz, though it does say take the Weiss below. Maybe its my phone or maybe it's me. Crazy
Fixes: 84
Re: Another...
You reached Key Stage 4 Smiley
Customer and Forum Moderator.
beeceegee
Re: Another...
Quote from: Strat
ditto (1 wrong)
nanotm
Re: Another...
I though a few of the "correct" answers were technically wrong, one of them blatantly so but hey ho I still got the same result I expect everyone else did of stage 4 .....
