Another (more technical) quiz [Solved]
The title 'Clever Clogs' goes to the first correct diagnosis of this:
Call me 'w23'
Fixes: 9
Re: Another (more technical) quiz
It's a graph showing noise margin Tongue
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Thanks Jelv,
Sorry I should have been more clear.
What made it jump from 15 dB to 22 dB!!! at 8-ish this (last?) morning?
Call me 'w23'
Wink
And, in the spirit of Christmas, it's NOT fairy lights.
Humbug to all,
The Grinch.
Call me 'w23'
Fixes: 9
Sorry, as this is in the General Chit Chat forum I didn't realise it was a serious question!
Not really that serious Cheesy
Call me 'w23'
Your answer (technically correct, of course) is not quite deserving of that fantastic prize.
Call me 'w23'
Fixes: 9
If you check your up time I bet you had a resync at that time. It could be any number of things that caused that but it's very odd that the noise margin went that high after the resync.
Fixes: 9
What does the sync speed graph show at that time?
getting warmer!
Call me 'w23'
Oops, sorry I attaced it twice.
Can I easily detach one?
Call me 'w23'
Yep, Modify -> Additional Options -> untick one.
pierre_pierre
Your a late riser and switched the coffee pot on
nope, just use the kettle; instant coffee is so much quicker, much prefer 'proper' coffee but don't have the time (or the inclination to wait).
Call me 'w23'
Fixes: 9
You have two ADSL lines and moved the router from one to the other?
