Android smat phone
rongtw
Fixes: 12
Android smat phone
i have just bought my first smart phone  Wink a sony xperia  with android jelly bean .
question is do i need any anti virus / malware installed ,,,, if so any suggestions
Fixes: 16
Re: Android smat phone
It's always best, there is some malware about for android.
I use Hornet AV does the job, a bit in your face when a file is downloaded but at least you know it is working.
Fixes: 50
I've had Avast free on my Samsung for 18 months and my HTC for 2 years previously but recently removed it.
It never reported anything in all that time so figured it was a waste of clock cycles.
Customer and Forum Moderator.
Yes, No, Kaspersky
Now Zen, but a +Net residue.
Fixes: 142
I've never installed any AV on my smartphones (but that may change in time).
I'm vigilant in its use never using unknown Wifi when out/about. When I do use Wifi away from home I don't download any files.
Forum Moderator and Customer
I've never installed any anti-virus on any of my smartphones.
Fixes: 9
Am I the only one who read the subject as Android smut phone?  Crazy Cheesy
Fixes: 16
Yep. I read it as smart phone, but I do have dyslexia
rongtw
Fixes: 12
yup i made a minor typo  Crazy
Steve
Seasoned Pro
Quote from: rongtw
Welcome aboard. I own a Sony xperia with KitKat operating system. Battery life is amazing for a smart phone if I'm honest I like it. As for Anti virus well Its not needed really just watch what apps you download, if any sounds dodgy just avoid them.
If life gives you lemons, make lemonade.
From what I've read, and I've had smart phones for many years (six at least, depends on definition of a smart phone)  and never had anti virus nor an infection.
Generally you will be ok if you DON'T tick the "Unknown sources" option. This usually off by default.
Enjoy your smart phone.
