Am I seeing a mirage / illusion or..........
TORPC
Has a request be granted & put in place, ahead of more important fixes ?Huh
Fixes: 247
Re: Am I seeing a mirage / illusion or..........
Nope
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
TORPC
I notice one word answers from you today, is this going to be a continuum Tongue Grin
Fixes: 247
yup Wink
RobPN
Seasoned Pro
Quote from: TORPC
Huh  Maybe instead of calling the offshoot 'Fibre' it would be better named either 'FTTC' or 'VDSL'  Undecided
Fixes: 19
Quote from: TORPC
He is in "energy saving mode" and hoping for some cashback from plusnet, for saving space on the forum server  Grin
Fixes: 9
275941 posts and counting ?
Fixes: 131
Quote from: RobPN
Maybe instead of calling the offshoot 'Fibre' it would be better named either 'FTTC....'
Where would FTTP go?
Customer and Forum Moderator.
TORPC
Alphabetically under FTTC  Roll eyes Lips are sealed
Fixes: 225
Quote from: Strat
To your home Wink
Forum Moderator and Customer
They should call it LCTF  Local cabinet terminated fibre
Now Zen, but a +Net residue.
nanotm
but some of it is actually terminated outside a persons home and called FTTK (since they already used c in cabinet they spelled kerb with a k...) and some is FTTN where the node is actually not the local cabinet .....
much safer to stick with the anomalous "fibre" title rather than have 6 different product options, of course fibre is still a type of DSL so it would of been more accurate for them to have titled it VDSL as all fibre products use a version of VDSL......
RobPN
Seasoned Pro
Quote from: Strat
Where it already is?  i.e. In the 'Plusnet Trials' section under 'Fibre To The Premises (FTTP)'.
When/if FTTP becomes a fully fledged retail product it could be moved out of that section into 'Help and Support'.
I only made the suggestion because essentially what appears to have happened is the FTTC threads have been moved into their own section ('Fibre'), and previously any threads about FTTP were moved by the Moderators to the FTTP section mentioned above.
Perhaps an announcement about FTTP is imminent?
