Alternative to Thunderbird for email client
- General Chat
- Alternative to Thunderbird for email client
28-07-2019 3:00 PM
I`m posting on General Chat, as this is a request for opinion, rather than a "techy" problem to be solved.
I have been using Thunderbird for years... but I "think" it may be causing me some problems, as mentioned on the tech board... so I am looking for an alternative ..
I don`t want any "whistles, bells, gongs, flashing lights" type of thing.... just a simple prog to download emails so I can read them and delete them or move them to "saved" folders.
Checking out the question on Google, throws up a couple of lists,... so, I am wondering if the members of the forum have tales, and anecdotes, to convince me that "their choice" is the best .
Claws Mail
Sea monkey
Mailspring
or anything you think may appeal to my simple mind !
Re: Alternative to Thunderbird for email client
28-07-2019 5:45 PM
Moderator's Note(s)
Several replies moved to>https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Freeze-or-rather-I-wish-it-would-NOT-F... at the request of the OP
Forum Moderator and Customer
28-07-2019 6:50 PM
I have been using Thunderbird for many years and not found a problem with it.
What problems do you think it is causing?
28-07-2019 7:15 PM
Have you tried contacting Mozilla about your problem?
28-07-2019 8:27 PM
@artmo I have been using it for about 15 years.... see my thread on tech board.
@Jonpe No... Often trying to contact them is fruitless and a waste of time... as it probably only affects me, or maybe a few others... they consider it "tough"...
This thread is about finding a decent alternative to Thunderbird... ( preferably one that I can migrate all my saved emails and address books to, fairly easily) ..
28-07-2019 8:49 PM
Never had a problem contacting Mozilla. Generally answers emails within an hour and their mods are amongst the most knowledgeable people I have come across.
28-07-2019 9:36 PM
@shutter a good alternative to Thunderbird is eM Client , who also offer a very good free version.
https://www.emclient.com/?lang=en
Also easy to transfer from Thunderbird
Hope this helps
28-07-2019 10:04 PM
@ITWorks thanks for that ! .... I`m running Linux Mint 19.1 ... and it says for Windows and MAC... I could "probably" run it under WINE which enables Windows type software to run on Linux machines ;... ( nothing to do with Virtual Box) .
Will look at it again, tomorrow, and see how it pans out.
29-07-2019 8:05 AM
@ITWorks I have just downloaded, and tried to install it , using WINE.. but I get an error report notice... with an email address to send the bug report to...
I have done that... with an explanation that I know it is for "windows & MAC " so maybe they will see if it can be fixed
Cheers
29-07-2019 8:51 AM
Your throwing the baby out with the bath water here @shutter!
By your own admission you’ve used this application for 15 years or more but you’re dumping it because of this one issue.
You would be better investing your time in finding a solution to this rather than a new client.
Start by uninstalling TB and FireFox s they're both in the same family using :
sudo apt-get remove --purge firefox thunderbird
To install the latest and greatest add the mozilla repository to your device.
sudo add-apt-repository ppa:mozillateam/ppa sudo apt-get update sudo apt install firefox thunderbird
I’m sure that once you does this all will be well, I hope, but if nothing else it’s surely worth a try? If it doesn't work for you at least you'll know how to remove it if you change Clients.
29-07-2019 9:06 AM
@Anonymous Hee Hee ! ! ! ..
Yeah.. you could be right there.... however,... I never liked babies ... cos they never liked me... so kept well away from them as much as possible..
Thanks for the sudo`s all noted for future use... will persevere at present... as it is all good learning stuff...
Since yesterday, when I started to use TB with so called "safe mode" ( why is it that it needs a "safe mode" is it "unsafe" when the addons, that come as standard fitment on install are enabled by default ? ? )
anyway.. since then .. so far this morning.. I have not had any issues of stalling. jerky mouse, unreliable/not working mouse or freezing...
But it will be nice to have an alternative to Thunderbird, and eM CLIENT may be just the thing... the offerings on the "software manager" do not appeal to me... nor do any that I have tried from a google search..
( don`t ya just love Linux ! ! ! )
29-07-2019 9:17 AM
Fair enough @shutter, but I'm going to suggest that you have nothing to lose by trying what I suggest above now. You'll then be able to try it running in normal mode and if that doesn't work, then so be it, you can return to plan A.
If you do when you first start TB there will be a notification telling you about the Calendar integration, you can disable it at this point before you add any accounts.
29-07-2019 9:21 AM
OK @Anonymous Does that first one, that has Firefox AND Thunderbird mentioned... remove, and replace both? all in one go ?
29-07-2019 9:27 AM
No, it just removes them if you want to you can do them individually.
sudo apt-get remove --purge firefox sudo apt-get remove --purge thunderbird
The reinstallation is done on the last line of the three command.
The first adds the Mozilla repository (the location where the applications are stored online).
The second updates the apt system with what it finds there.
And the last line does the installation and like above you can do these separately if you want.
I'm suggesting both as they are from the same family so makes sense to do both.
29-07-2019 9:36 AM
OK.. Thanks very much...
- General Chat
