All I wanted for Xmas - a room heater
Had the missus won the lottery I'd have requested this room heater as a Christmas present. As a Bentley salesman would say, "the power is sufficient."
Any other Christmas 2012 lists out there?
Now Zen, but a +Net residue.
James
Re: All I wanted for Xmas - a room heater
Now that's just a bit silly.
Fixes: 16
Am I missing something?  where does it say what the heat output is?  (presumably it is "hot air" heating)
but how many Kw of heat is produced?
and is it `A `rated for electrical efficiency  Roll eyes
Fixes: 62
Powering it all is a 1,200-watt power supply (PSU).
Fixes: 16
Erm.... I think that is the amount of power it "draws" from the supply... not the "heat output"....  Roll eyes
same thing Watts equals Joules per second Cool
An electric fire is rated in watts or kilowatts
and all the electric energy is turned into heat because there is no turning shaft or other power takeoff  Wink
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
whelpton
The Falcon Northwest Mach V. I can see they subscribe to the 'Gillette' naming system.
The power consumed/output as heat will vary depending on the processing load. Most likely the cooling fans will run faster drawing more power as well. With a good game running it will probably pull close to a Kilowatt.  However the the grand-kids will soon get suspicious when granddad's new "heater" coupled with a 100Mbit dedicated optical fibre is now consistently beating them at Battlefield 3
